LT1 vs LS1
check out www.LS1sounds.com
I have seen that pic a hundred times but it's usually got a 4 banger under Richards arms not an LT1.
I was about to say how bad that is for you to post that. But then I see you drive a 97 Z28. So I guess it's like the black guys that use the "N" word. It's ok for you to use it
WTF?
First off, all out for a Heads/Cam LT1 is not 380 rwhp, they can hit that with some bolts on and stage 2 headwork/cam.
Stage 3 guys hit 420-480rwhp and sometimes more with highly modded stage 3 LT1's.
And the 'stroke' is determined by the crank.
A 383/396 stoked LT1 is just the beginning.
You just can't beat the firing order and cast iron of the LT1 when it comes to sound.
LS1's sound like popcorn machines even with large cams.
Believe me when I say that there is always someone out there that wants to own a record. I'm sure several people have made attempts at a 7 second LT1 and fell short for reasons other then cash.
Motors and mods go hand in hand. The good news is that both the LT1 and LS1 respond very well to them. You just have to accept the fact that stock for stock the LS1 is faster, mod for mod (mods and trannies being equal) the LS1 is faster.
You don't need to take that personally because it's absolutely not personal. I don't take it personally that 03 cobras are faster then LS1's stock for stock and mod for mod.
IN FACT I STARTED WITH A LT1 CAUSE I WAS GOING TO BOOST IT AND I WANTED AN IRON BLOCK AND 5 BOLT HOLES PER CYLINDER TO START WITH......ALSO I DON'T PUSH COOLANT LIKE AN LS1 BLOCK...
I use to own an LT1 and think like you too b/c I had never owned an LS1 and always felt like an underdog. LT1 is a great motor, but be realistic on results. You have to do a crazy heads/cam to get 480 out of a LS1.
I agree that his #'s seem out of whack for a H& C lt1. Two things concern me about you though. First who the ***** does the "LT4" conversion?? Thats a joke! And do you actually have the intake in your sig? They suck bro!
Coonass enjoy your LS1.... I am going to stay out of the LT1 section.
