LT1 vs LS1
http://batonrouge.craigslist.org/car/488385034.html has a newer LS1 style fron end on it too.
Is the LS1 a superior engine? Yes. in almost every way. I still love my LT1 though, I've never owned an LS1, but I know my engine has almost 90,000 miles and 15,000 of those were from me. I have driven the pure **** out of it, and it's still driving wonderfully. I'm not saying I've never beaten an LS1, but it's rare. More common than not, I would say it's because the LS1 guy couldn't drive at all (because I'm not THAT experienced of a driver to begin with).
So like Powder99SS said, it's all about personal preference.
Hope this helps.
by the way here is some lt1 info
BASIC LT1 SPECS
Block and Basics
Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
Block Material: Cast Iron
Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
Stroke: 3.48"
Bore: 4.00"
Compression Ratio: 10.4:1
Combustion Chambers: 54 cubic centimeters
Factory Redline Rating: 5700 Rotations Per Minute
Bottom End
Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
Connecting Rod Material: (10108688) Powdered Metal
Crankshaft Material: (12556307) Cast Iron
Top End and Valvetrain
Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*)
Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
Valve Overlap: 41*
Valvesprings: (10206040) 85 lbs, seated
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
Rocker Arms: (10089648) 1.5:1 Stamped Steel
Timing Chain: (10128485) Powdered metal butt link
Intake and Fuel Delivery
Fuel Delivery: Electronic Fuel Injection, sequential port
Injector Size: (17124248) 3.0gps, 22lbs/hr speed density (1992-1993), 24lbs/hr mass airflow (1994-1997)
Throttle Body: 48 millimeter twin butterfly
Intake Manifold: (12552137) Aluminum
Factory Power Ratings
92-96 LT1 Corvette: 300bhp, 330lb-ft
1996 LT4 Corvette: 330bhp, 340lb-ft
1992 LT5 Corvette: 375bhp, 370lb-ft
93-95 LT5 Corvette: 405bhp, 385lb-ft
93-95 LT1 F-Body: 275bhp, 325lb-ft
96-97 LT1 F-Body: 285bhp, 325lb-ft
96-97 WS6/SS: 305bhp, 335lb-ft
93-97 Firehawks: 315bhp, 340lb-ft
Factory LTX Camshaft Specifications**:
1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
* Cast iron heads are known to flow better, but are also more prone to heat-soak than aluminum heads.
** Thanks to Metalbeast@LS1TECH for these specs
And highway runs are a night and day difference. Now just make sure you get the model and transmission you want. Don't settle for a A4 Z28 if you really want a M6 WS6.
Good luck.
My brother has a 99 z28 6spd...and I dislike it for that reason.
That reason alone. Otherwise, I'd have one in a heartbeat. I just think the LT1s are better put together. For a streetcar/DD, you can't go wrong in either. They feel similar, the LS1 just pulls harder up top, but I like the drivable TQ of my LT1 and is alot more fun around town.
Buy what you can afford. I have a 5k LT1 with higher milage than my bros 5k 99 LS1. He got a hellava deal...but I like T/As
To get an LS1 t/a I'd have to spend 10k easy to get what I want. You old guys here all about milage, are justifying 14k for a T/A and making the LT1 a far better buy at 5-6k. Higher milage cars can run just fine. My 155k lt1 screams all day long, as does the 130k z28. I just enjoy 3:42s more than 3:23s
I agree that there are a lot of high mile LT1's still running strong. But now that enough years have passed we are seeing some 100K, 120K and even a few 150K ls1's running just as strong. I don't think longevity is a problem with either motor if taken care of.
-Tom
http://losangeles.craigslist.org/lac/car/507313547.html
http://losangeles.craigslist.org/wst/car/508631720.html
But they are cheap. Which brings me to a couple of old sayings:
1). You get what you pay for.
2). If something looks too good to be true it probably is.
There are a lot of scammers out there trying to rip you off so be careful coonass350. Good luck and happy hunting.
