Removing A/C Condenser
Old Jan 21, 2008 | 02:16 PM
95ZLT1's Avatar
Default Removing A/C Condenser
Well if the title didn't give it away im planning on removing the a/c from my '95 camaro. The compressor looks pretty simple to remove. I already have the delete pulley i got from the dealer i work at so im good there. I was just wondering if you guys have any tips on removing the condenser. Any advice would be greatly appreciated. Thanks
Old Jan 21, 2008 | 03:23 PM
I8ASaleen's Avatar
Ummm unbolt the lines that go to it and viola you take it out. It's not too hard just takes a little cursing. Now getting the lines that go from the compressor to condensor and vice-versa are ridiculous, have fun with those. All in all you are gonna have bruised knuckles.
Old Jan 21, 2008 | 03:28 PM
95ZLT1's Avatar
That simple huh. Well i feel a little stupid, someone told me it was a pita. Anyway, thanks for responding.
Old Jan 21, 2008 | 03:33 PM
I8ASaleen's Avatar
That's it, it is a pita, but fairly simple. Make sure all the lines are disconnected, the top air dam is off and get a good hold of it from the front- then it should come off. Really the hardest thing was getting my hand around to the A/C compressor and yanking the lines out
Old Jan 21, 2008 | 03:42 PM
95ZLT1's Avatar
Sounds like it just takes a little patience and small hands. If thats the case i should be alright. Im also going to put it up on a lift for better access underneath.
Old Jan 21, 2008 | 03:51 PM
I8ASaleen's Avatar
Good idea, b/c that way you don't have the wrong angles I did just having it on jackstands. Have fun and don't forget to plug the holes in the evap block the the lines leave or you'll have goop running outta them.
Old Jan 21, 2008 | 03:57 PM
95ZLT1's Avatar
Will do man, thanks for the pointers.
Old Jan 21, 2008 | 05:20 PM
The Engineer's Avatar
Once the condenser is removed, you may want to install some aluminum spacers to duct the air and prevent an air leak. The photos tell the story.
WD
Old Jan 21, 2008 | 05:31 PM
95ZLT1's Avatar
Thats a good idea. Where might i find one of those and roughly how much am i looking at pricewise?
Old Jan 21, 2008 | 05:42 PM
GreatWhiteZ28's Avatar
ya'll do this with the radiator in the car???
Old Jan 21, 2008 | 05:57 PM
I8ASaleen's Avatar
I did. It wasn't too bad.
Old Jan 21, 2008 | 08:04 PM
the_merv's Avatar
Veteran: Air Force
To take the AC out...Dremel and a 6-pack..
