Head & Cam Price?
Rings?
Rebalancing?
Gaskets?
This is going to cost you more than $2500 all said and done.
You can not do a QUALITY shortblock for $1300 corners will be substantially cut somewhere. A well done shortblock machineing and assembly will likely cost that without the parts.
Could you polish a turd a little and improve on the stock setup some, sure, but you are not going to make big changed like boreing and quality forged parts and come in that cheap.
A $200 forged rod might even go out of round just trying to check bearing clearances because they have not been stress relieved before machining.
Later,
Devin
Later,
Devin
If the OP wants someone to do it for him, then the charges will rack up quick. Sounds to me he needs to stay a bolt on car considering its his DD. You are right though Devin, the charges add up real quick.
The prices ive mentioned what we charge at my work. (chevy dealership)
What I really ment was just the heads, like then RR's, rods, etc,etc and then a cam of your choice, with the install. If I am wrong about the heads let me know cause I looked LT1/LT4 heads on their website and I seen 2k for their heads, and I didn't know it came as a package. I was also saying a total install as well of theses parts, cause my local dynoshop charges a rate of 75 bucks per hour. Hey this is where I got that heads price
http://treperformance.com/i-61916-af...der-heads.html
Later,
Devin
Been a few guys who got pissed off at my responses in the past only to later PM me asking for help fixing the mistake they made in ignoring the experianced guy
. Good luck, you will sure as hell need it.
chaves885, consider $2000 for heads and cam but then add say $120 for pushrods, $50 for studs $50 for Isky adjustable guideplates, intake porting/angle milling $3-400, rockers $260, $100 in gaskets, maybe $175-200 for core heads, shipping parts back and forth another $50, $100+ tuning. $3000 can happen in a hurry once you consider everything.
Have not even talked about headers/gears/CAI, stall and shift kit, where applicable, and all the other supporting mods.
