3 questions i need answers for pls.
1st question:
1995 Camaro had "Vented Opti" what exactly does that mean? Does it mean i can pressure wash my engine without worrying about my opti getting fucked?
2nd question:
I'm going to go with the LT4 hot cam kit, do i need to replace my oem chain? I know the LT4 timing chain is more beefier.
3rd question:
Since i'll be going with the hot cam kit, i'll also swap my lifters (lazy lifter)
I ordered some LS7 lifters. Do i need to get smaller or bigger pushrods?
Thanks.
2nd question:
3rd question:
Thanks.
i'll answer ?#2... if your timing chain is old with a lot of miles or you find a lot of slack in it then it would be good to replace it when doing a cam swap, otherwise you'd be fine with the chain that you have. when replacing a chain the stock replacement chain will be just fine for your application
1st question:
1995 Camaro had "Vented Opti" what exactly does that mean? Does it mean i can pressure wash my engine without worrying about my opti getting ****ed?
2nd question:
3rd question:
Thanks.
2nd question:
3rd question:
Thanks.
2. If you going to have it torn apart, replace it. My motto is do it right the first time.
3. You should be fine with your stock pushrods. I think the LS7 lifters are the same specs as the stock ones. But I don't know for sure.
#3 You need to check for proper valvtrain geometry when changing the lifters. I think there is a variance from LS7 from LT1 lifters. I think you will need a different pushrod.
You must get an adjustable pushrod and check springs to do this.
we swiched the ls2 to the ls7's in our ls2 and used the same push rods so the geometry is the same, but now if you swiched to a cam w a smaller base circle the the push rod would need to be longer
you have to replace a timing set as a set everytime or the uneven unequall ware will just tear up everything. yes you can do it, but its just like the chain and sprockt on a street bike and dirt bike it all has to be changed as a set
#1 yes, vented opti is called vented because of the extra vacuum hose that runs to the air breather, you can wash any engine with an opti, as they said just try not to spray direct pressure on it, especially if it is old, the caps tend to warp slightly and like to let moisture in them.
#2 Yes you need to replace the timing chain, only for peace of mind/insurance reasons, the lt4 timing set (note i said set, yes you do not want to replace just the chain, replace it as a 3 piece set) is a direct replacement and will bolt up without any modification.
#3 your factory length and size pushrods will work with those lifters, but I agree I would get a new set, gm performance parts sells a set of hardened pushrods for the lt1/lt4 that is very inexpensive.
hope the info helps.
