lt1 DART heads
Old Feb 1, 2008 | 06:58 PM
kierstyn's Avatar
Default lt1 DART heads
Hi i wanted to know if these would bolt on a stock bottom end and not kill the compression like the afrs and trickflows? Just wanted to see if anyone had any experience with them yet? Thanks
Old Feb 1, 2008 | 07:18 PM
fordeater's Avatar
also wondering about the dart heads too, in the latest chevy rumble they had a pic of the lt1-lt4 pro 1 heads and they had guide plates on them, I was wondering if those are correct guideplates for our cars or if they were just sbc ones.
Old Feb 1, 2008 | 07:48 PM
fergymoto's Avatar
A SBC and LT1 are going to use the same guide plates. Side from the cooling a LT1 head is just a plain 23* SBC head.
Old Feb 1, 2008 | 08:04 PM
96capricemgr's Avatar
The valve spacing on the GM LT1 heads is slightly different than gen 1 smallblock heads, BUT aftermarket LT1 heads are all just converted gen 1 heads, but converted I means usually they retool at the factory to make an LT1 head using existing ports and chamber, I do not mean converted after the fact.
From memory I think the Darts as with most of the aftermarket LT1 heads have a big 62-4cc chamber, again this goes back to the fact they are basically a gen 1 head tweaked to work with the LT1 intake pattern and reverse flow cooling.
One guy who occassionally posts here has run them and I believe they ran what mildly worked GM aluminums ran.
IMO do not bother with them, but what do I know?
Old Feb 1, 2008 | 09:02 PM
fordeater's Avatar
so its bascally a gen1 head but has reverse cooling and lt1 bolt pattern...I thought for a second there that someone made a better bolt-on guideplate other than the GM's or iskys.
Old Feb 1, 2008 | 09:11 PM
Taubr Unit's Avatar
I like thoes heads too. Heres some food for thought.....
--58cc Combustion Chamber Volume
http://www.advancedinduction.com/AiProductsLTxDart.html
Old Feb 1, 2008 | 09:47 PM
Read the last sentence of the second paragraph.
Guess I was wrong on the chamber.
Old Feb 2, 2008 | 01:33 AM
gatorhead's Avatar
I know that the AFR's and the Darts can be ordered with different chamber sizes.
