Any Estimates
355:
Trickflow heads (Im only paying 450 for them and my stockers are shot)
Eagle crank, GM rods, 11:1 compression on the 64cc heads
CC305 cam, GM LT4 Rockers, New lifters and hardened pushrods
Pacesetter longtubes ORY Hooker catback
CAI and 52mm tb and port matched intake
And a dyno tune.
I don't see it running low 11s either. I'm assuming the heads are as cast rather than ported (since you didn't specify that + only 450). So basically you have a mild h/c setup with boltons. I would aim for mid-high 11s with that.
The GMPP rockers are lift capacity limited and you will be near that limit, have to make sure the geometry is right or you will risk bottoming the rocker slot on the stud.
As cast the Trickflows are not worthwhile but for that price, I certainly see why you are doing this.
The cam is a poor choice, is it another piece you got a screaming deal on or can we help you make a better choice.
You put it together like this and I am going to say mid 12s with a decent but not great launch.
