10's w/Ai 355 pump gas VIDEO
Hi all. It's been a long time since I have had the car on the race track. The last time out I was plagued by electronic issues, and poor tuning. I made good peak numbers, but the car didn’t drive very well. Initially I thought it drove okay, but compared to what it's like with a proper tune it's a completely different car. It starts easy, idles steady, and gets better mileage. It always ran strong at WOT, but I have fixed the part throttle tuning across the board. Finally, it drives normally. Last week I had and opportunity to head down to Ai & tune up (break-in and testing) a couple of engines for Karl Ellwein as well as Rick Abare's 383 on the dyno. The weather in North Carolina was in low 70's with clear skies, so the guys convinced me to bring the car down and try running it again. Those of you who are familiar with my car will remember that the last couple of times I tried to run the car I destroyed several 12 bolt gear sets, and a drive shaft. In the end everything turned out pretty well, and I had a really good time. I made a bunch of passes, the car went decently fast, and I didn't break anything.
Here is a quick video of some dyno and track action. Sorry for the shaky video, we had sustained 20-22 MPH headwinds with 30 MPH gusts.
http://www.youtube.com/watch?v=vWMmDbzf_SI
There is some tweaking I need to do in regard to the gear ratio, and tire combination. I should be able to get it quicker with better conditions, and the before mentioned changes.
very nice...
by the sounds of it you could probably benefit from a bit more gear ?
EDIT : I did not look past th vid link to see you noted you need some tire and or gear changes which should really get the car working.
Wow,
I'm in a good mood, I just talked to the guys a AI a couple weeks ago about the 200 heads I'm gonna do it I just gotta save a little bit more $. What does sr cam stand for and why did you go with it over the 306?
