Spent some money..
#42
that was due to some underwater cables being cut during an earthquake off the coast of Italy. where i work we have a business unit in India that does all the tedious stuff. since the net was down over there we had to do all the work they do out there. it was a nightmare.
#43
okay guys since merv couldn't remember i did some searching and voila:
http://www.hawksthirdgenparts.com/shocks_2.aspx
Hawk's has the setup on their website for 550.
#44
That's MISTER MODERATOR
YAH-HA!!!
Thanks C_Rules
It's a Spohn product.
I'm finding that Speed Engineering has some good pricing on stuff.
http://speed-eng.com/store/
It seems to me to get the best trick chassis & suspension parts, a good mix of UMI, BMR and Spohn is needed. They each have at least one goodie the others don't have.
Thanks C_Rules
#45
you're welcome let me know if you get them and how they work out for you on our mean streets. i haven't taken the car to the track since i stroked the motor. if the car doesn't hook when the track re opens its good bye kyb adjustables and pro kit. i'll go with a qa1 or strange coil over setup. been reading some good stuff about strange seems like they're a little less expensive and work just as well.
#49
www.spohn.net also has the coil overs.I have been looking at them for a while and wasnt sure about buying them until reading this thread.Got a little money to spend when I get home from afghanistan in a couple weeks
#54
do they still mount to the little tabs that the shock bolts to? IT seems alittle much for the entire car to be suspended on just that little guy... especially with the LCA relocation brackets... Is that okay? Im not an engineer, so I dont know... And if it is okay... anyone looking for a brand new set of rear QA1 shocks(not coil overs)? Cuz I like this set up way better... if its sound...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#56
good enough for me! I dont much like having to rip into the interior each time i want to change the shocks... so 1 more time wont hurt, if it means thats the last time. Plus, it seems like the gains are awesome.. when i bought the car it had those ground control spacers in it... they are horrible... unless you spot weld them to the rear... and I never did... so bump bump bump was all I heard... this is gonna be a step in the right direction. Already have the QA1s up front, so this is gonna set me up hopefully...
ANYONE WANT SOME single adjust rear QA1s?
