How is the GM847 with stock heads & bottom?
Old Feb 22, 2008 | 11:52 AM
JoeliusZ28's Avatar
Default How is the GM847 with stock heads & bottom?
as the title states.
Ive been stuck on the 224/230 for the longest time but im afraid it wont be big enough. Is the 847 too wild if i want to shift at 6200? (im not necessarily concerned about not getting the most out of my cam)
How is the torque down low?
Old Feb 22, 2008 | 11:56 AM
GreenBlood's Avatar
a cam like the 847 is jut too big for stock heads. Can you run it, yes. You will see more gains from a smaller cam with stock heads. The 847 needs to breathe just like any other big cam and would like to be spun up to about 6500-6700 RPMs. You wouldn't be getting the full benefits of the cam. Smaller cammed guys on stock heads will most likely outrun you. If the cam can't breathe, your not going to see much out of it.
Old Feb 22, 2008 | 11:57 AM
GreenBlood's Avatar
another quick question, why would you not want to get the most out of your cam? what would be the point of even doing the swap then?
Old Feb 22, 2008 | 12:06 PM
JoeliusZ28's Avatar
because the 847 makes more power from 4000-up than the 224/230.
Old Feb 22, 2008 | 12:07 PM
infinitebird's Avatar
847 is definitely too big for stock heads. You can make good peak hp numbers, but you will make more power under the curve with a smaller cam.
Old Feb 22, 2008 | 12:08 PM
GreenBlood's Avatar
yea, but if your only revving it to 6200, you're really not going to see much of a benefit IMO...
Old Feb 22, 2008 | 12:14 PM
JoeliusZ28's Avatar
847 peaks at 6200...
Ive read elsewhere that 1.5 rockers are good on this cam to "tame" it down a little.
sounds like consensus is that i should go with the 224/230 then? ugh... i just dont think its big enough.
Old Feb 22, 2008 | 12:21 PM
Why are you wanting to jump to the 847 just cause you don't think that cam is big enough? There are many other cams in between those sizes that would be more appropriate with stock heads than the 847.
Old Feb 22, 2008 | 12:22 PM
Which means you want to be shifting around 6500-6600.
Old Feb 22, 2008 | 12:25 PM
GreenBlood's Avatar
exactly...can you find anyone to do a custom grind for you? maybe that will suit you better...
Old Feb 22, 2008 | 12:42 PM
1994Z28Lt1's Avatar
i would suggest getting your heads ported first because that would help even the cc503 i assume thats that cam your speaking of at 224 230 its a great middle of the road cam which will put down some awesome power with ported heads
i think some of the people on this board are putting down over 360 at the wheels with that cam and ported heads
Old Feb 22, 2008 | 12:45 PM
JoeliusZ28's Avatar
please educate me then, i only know of the 230/236 which i havent seen much good results with.
I want a cam that im going to enjoy. This car is not my daily driver by any means, it probably gets 2k miles a year or less. Ive driven a handful of cammed LS1s, and so far my favorite cam for that engine is the torquer V3 which i believe is like a 231/234 on a 111. I wish there were some middle of the road cams like that for LT1s.
edit: heads are not going to be ported on this motor, this one is going to stay cam only. Im going to save ported heads for my next engine which wont be built on a college budget.
Old Feb 22, 2008 | 12:58 PM
Schweet97Z's Avatar
a friend of mine put down 364rwhp and 374 rwtq with the 230/236....
Well there are actually 2 230/236 cams (the xe and xfi ones from comp) and people have done well with those (over 360rw on stock heads), then there are the 2 AI cams 226/234 and 230/238, there is the comp 233/239 (probably still too big), Lunati has several one 226/234 and a 231/239 I think.
And there is always custom.
Old Feb 22, 2008 | 01:00 PM
although to the OP, if you don't want to shift past 6200, I don't think you will get much from a larger cam than that one.
Old Feb 22, 2008 | 01:19 PM
zigroid's Avatar
if you're willing to rev it, gear it, and set it up properly, the GM847 will go faster.
that is atljar's GM847 cam only dyno a few years back. he was running 11.9s @ 115 with a 6 speed.
the cam runs just fine when it is set up properly. don't let anyone discourage you. smaller cams are for daily driving. larger cams are for racing. which one do you want to do?
edit:
http://www.camaroz28.com/forums/showthread.php?t=190876
more info
his website is down but from what I gather:
60: = 1.687
1/4: = 11.98
mph: = 115.44
-1150 DA
Left at 6k+
GM 847 cam, supporting valvetrain
TB is 52mm, stock throttle body, bored over by halbert performance
"Race weight = 3800ish (guessing), not a lightweight by any means. Nothing has been removed (not even jack/spare), plus 10 inch sub, and amp, plus 12 bolt, plus me etc etc."
Its lowered, lower control arms with brackets, and a panhard bar.
Rest of suspension is stone stock
12 bolt rear w/ 4.33s
Tire/wheel combo:
Front: Weld drag lite skinnies, with some VW van tires on them.
Rear: 16 inch 5 star TA wheels, 26x11.5x16 ET streets@ 14psi
http://www.youtube.com/watch?v=zvx-cAvoy4M
Old Feb 22, 2008 | 01:33 PM
StealthFormula's Avatar
If you dont want to spin past 6200rpm you will even be hindering yourself with the cc503 even. Either look into some smaller cams or decide if you want to take the risk and spin the short block up higher so you can run a larger cam.
you should read this carefully:
https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
Old Feb 22, 2008 | 01:52 PM
I agree to a certain extent. Although I think that dyno sheet is very illustrative of how limiting the stock heads are with a cam like the 847, like I said in the stock head/cam thread. 11s with a 6 speed is quite good though considering everything.
Old Feb 22, 2008 | 01:56 PM
Revelation Z28's Avatar
or you can go big just in case later down the road you decide on a 383/396 etc or aftermarket heads so you already have a cam that will feed the bigger displacement or heads. the CC306/847 is a good cam. you drive your car as much as i do and im set for the 306 or a custom grind thats .600/.610 lift and whatever duration the guy calls for.
Old Feb 22, 2008 | 02:00 PM
JoeliusZ28's Avatar
thanks i will look into those cams.
https://ls1tech.com/forums/showthread.php?t=836200
Ive been reading these boards a lot longer than you think... Ive been set on the 224/230 for a while now, but it just seems like too much of a daily driver cam for me. I like having a rough idle, cam surge, and a kick-in-the-*** top end. My car is NOT a DD, i would rather go too big than too small. I think some of the cams infinitebird just posted might be a better choice for me than the 847 however.
As far as revving to 6200 goes... thats just me setting a guideline for myself because im much more concerned about keeping my motor together than running a tenth faster. Id rather have the power on tap and not push it to its limits every time than the other way around.
Im also kind of relying on the fact that i have stock heads to keep my engine from wanting to wind straight to 7k. Id like to rip right up to about 6000 and then yes, kind of run out of breath at that point.
