How big of shot with stock longblock?
Old Feb 23, 2008 | 10:12 PM
azboostin's Avatar
Default How big of shot with stock longblock?
I have a 1993 z28, and interested in nitrous... curious how large of wet shot can be run on these cars... car will have basic mods,,, fuel pump, headers, ect... and in good mechanical shape.
Old Feb 23, 2008 | 10:15 PM
96lt1m6's Avatar
i would not go higher than 150 WET and no more than 125 if you use a dry system
CamaroRacing12's Avatar
i have heard a 125 shot is safe... but i dont know much about it.... just from what i've heard
Old Feb 23, 2008 | 10:30 PM
azboostin's Avatar
planned on wet so thanks! do you guys think 11's are possible with camshaft, exhaust amd 150 shot... 3.55 gear a4 trans
Old Feb 23, 2008 | 10:32 PM
yea dude go for it... 11's r possible with bolt ons (11.80) record bolt on
Old Feb 23, 2008 | 10:36 PM
96lt1m6's Avatar
sure do! it has been done before...with no cam......
94 m6,Lts,ory,3.73s,nitto 245/50/16,52mm,madztune,K&N cai 13.33 N/A and 11.37 on a 150 @ 2700' DA mph was 107NA and 119 juiced..
Old Feb 24, 2008 | 12:32 PM
jakesz28's Avatar
I ran a lot of low 11 second passes with a cam and a 150 shot. I would not worry about spraying a 150 shot wet or dry the load on the crank is the same. I would check the air fuel ratio with a wideband either way. I have personal pushed a fair amount of nitrous thru a stock short block. Lets face it if the motor has loose bearings you will have problems but these motors can take bigger shots if the AFR is right and you are pulling the right amount of timing for the shot.
Lock at the time in the sig. That was with tranny and converter issues.
Old Feb 24, 2008 | 07:24 PM
azboostin's Avatar
can 150 shot be ran with stock timing and colder plugs?
Old Feb 24, 2008 | 07:26 PM
AR15 guy's Avatar
I know a guy that ran a 175 shot on his stock long block for a LONG time. He had 13X,000 miles also. It was a weekend strip/street car so he wasn't worried about long life but he couldn't kill it.
He ended up putting a built 383 stroker in it after his electric water pump went out and blew a head gasket.
I'd say a 100 shot on stock timing with the right plugs from a wet kit but you may want a tune.
I have a complete LT1 wet kit I may part with for around 750$. Comes with everything, kit, bottle heater, purge, switch panel, brackets, fuel pump ect ect.
Old Feb 24, 2008 | 07:46 PM
azboostin's Avatar
what are you guys using to pull timing? dont tell me msd boost master..
Old Feb 24, 2008 | 08:59 PM
Taubr Unit's Avatar
A tune will do it. I have a obd1 cable and a flash program so all i do is get a tune from Ion@madz28.com with how much i want retarded and flash my computer. I have a tune with 1-2-3 deg. retard so i have all my ends covered for whatever shot i run. Personally i like that better so the actual computer is retarded and im not relying on a aftermarket piece for it. Or you can get a MSD box with a retard box for it.
Old Feb 24, 2008 | 09:03 PM
jakesz28's Avatar
A Mallory 685 here. I've pulled up to 10* while spraying too.
Old Feb 24, 2008 | 09:10 PM
96capricemgr's Avatar
Get carried away with stock ring gap and it can close up and rip pieces of the top off the piston.
