Easiest way to put headers on.
Old Feb 26, 2008 | 08:23 PM
Huff035's Avatar
Default Easiest way to put headers on.
Ok my transmission is currently out of my car so i figured that is would be easier to install my headers now. Does anyone have any suggestions on the easiest way to install headers? Either way its going to be a PITA but i was just wondering if anyone had some suggestions from experience. Thanks ahead of time.
Old Feb 26, 2008 | 08:36 PM
Razor_Blade's Avatar
I wouldn't put LT headers on with the trans out of the car, since you might have to pull them off to get the trans back in.
Old Feb 26, 2008 | 08:50 PM
Huff035's Avatar
ok so if i wait until the trans is back in what is the easiest way?
Old Feb 26, 2008 | 08:52 PM
BOLO's Avatar
I installed a set of Jet-Hot long tubes when the trans was being serviced, no problem there.
Put the car as high as you can safely on jackstands and you should be able to install them easily. Good luck.
Old Feb 26, 2008 | 09:18 PM
It's hit or miss depending on the headers. I've dropped the trans on long tube equipped cars with the headers in place a few times, but I've also had to remove headers to drop the trans. I had to grind the bell housing for clearance before I could bolt up the pacesetters on my LT1 car. There is no way I could have stuck the trans in with the headers bolted up.
Old Feb 26, 2008 | 10:25 PM
BOLO's Avatar
Like I said, I have Jet-Hot long tubes,same design as Hooker's. I have taken down my trans several times, in fact once a year just to refresh the internals. Never had to touch the headers at all.
Old Feb 26, 2008 | 10:29 PM
sprayed_z's Avatar
You sure your motor mounts aren't sagging some? Pacesetters should bolt up fine without clearance issues, unless your motor mounts are sagging or bad. Go with some poly mounts
Old Feb 26, 2008 | 10:54 PM
LT1Formula007's Avatar
^^^^Agree Check your mounts, they could be bad. Pacesetters should fit w/o any problems.
Old Feb 27, 2008 | 06:43 AM
Go back and read what I said. I don't doubt you the least bit. My point was simply that it doesn't always work. That's why I told the OP in my first post that he MIGHT have problems, not that it couldn't be done. I've saw it happen both ways over the years.
Sprayed_Z & LT1Formula007, think about it LOL. The motor mounts will in no way change the relationship between the headers and transmission.
Old Feb 27, 2008 | 02:35 PM
Huff035's Avatar
So wat i got out of all of that is to put it as high as i can on jack stands. you guys kinda got off on your own little thing. whats the easiest way to get the manifolds off? and other than jack stands wat is the easiest way to put the headers on?
Old Feb 27, 2008 | 02:37 PM
Huff035's Avatar
Ive heard that its easier if i would unbolt the motor mounts and jack up each side of the motor to get them off.
Old Feb 27, 2008 | 03:49 PM
themadspoon's Avatar
I have taken my trans out with longtubes and y pipe on i would not worry about it at all.
Old Feb 27, 2008 | 03:57 PM
I had to unhook the passenger side mount, but some people get them to fit with out unhooking any mounts.
I also removed the steering knuckle, alternator, starter, oil dipstick, and spark plugs. Don't forget to unhook the battery before removing the starter and alternator.
Old Feb 27, 2008 | 04:40 PM
chavez885's Avatar
Where are you located? I'm sure some locals would help you out.
Anyways like razor says, remove alternator,dipstick,plugs,starter, and you'll probably have to remove the steering linkage on the driver side, it's a pain in the *** to get off. The higher you jack the car, the easier it is to put the headers in.
I advise doing it from underneath. Tape the header gasket to the header to make it easier on yourself, and make sure you get some good gaskets. Are you hooking up the AIR or EGR? If not, that will make this easier.
Old Feb 27, 2008 | 08:59 PM
wrd1972's Avatar
Lots of beer and band-aids.
Seriously get some double hex bolts like Stage eight locking header bolts. They have (inner) allen head and (outer) hex head which make things easier.
Old Feb 27, 2008 | 10:19 PM
Huff035's Avatar
yeah i am hooking up all the emissions stuff. im not really all that excited about starting this. lol.
Old Feb 27, 2008 | 10:21 PM
Huff035's Avatar
should i get new 02 sensors when i do this?
Old Feb 27, 2008 | 10:32 PM
Pro_built7's Avatar
no don't get new o2's right away b/c sometimes the ceramic coating kills o2's and you'll need new ones anyway. oh and if you ask me the easiest way for the pass. side is to unbolt the engine mount and jack the car up like 1 inch slide the header in from the top, hold it in place, and let the car back down onto the mount and replace the bolt. I seriously just did this less than 15 minutes ago and it worked fine.
Old Feb 28, 2008 | 02:17 AM
State69champ's Avatar
Find a lift and do it then.. Takeas much as you can off with the car on the ground then list the car up...
Take off the steering linkage also..
took me less then 6 hours.
Old Feb 28, 2008 | 02:19 AM
Drive around for a little while get them heated... your car will start acting stupid after a while and you SES light will come on.. then change your o2s.. dont forget you will need extentions I got 24inch ones and it worked fine..
you may also want a box of sparkplug wire hanging around.
