1.6 roller rockers
Old Mar 2, 2008 | 07:55 PM
White 96LT1's Avatar
Default 1.6 roller rockers
would i see a gain bolting in a set of self aligning 1.6.1 roller rockers in a complete bolt-on 96 Trans Am with a newly built 355 LT1? I plan on eventually going to a a LE2 or LE3 package. I was just wondering if i would see any gain in putting this on a stock cam? I do have bigger aftermarket polished valve covers from ebay on it right know for clearance.
Thanks for all your help guys
Old Mar 2, 2008 | 08:20 PM
BOLO's Avatar
Yes, why not. Maybe 10-15 hp. Adds a slight lift on the stock cam. One of my first bolt-ons back when the car was new.
Old Mar 2, 2008 | 08:38 PM
M6 Swap's Avatar
do you need bigger valve covers for that install
Old Mar 2, 2008 | 09:21 PM
BOLO's Avatar
No, the stock ones will clear w/ no issues.^
Old Mar 2, 2008 | 09:30 PM
97badass's Avatar
but will you have to tune the car again?
Old Mar 2, 2008 | 09:37 PM
BOLO's Avatar
Again,no. Not a significant change that would require a tune.^
Old Mar 2, 2008 | 09:51 PM
M6 Swap's Avatar
is it a hard mod to do?
Old Mar 2, 2008 | 10:05 PM
daniel6718's Avatar
no but you do need to do springs while your at it...and if your going to later do heads id reccomend going with nsa rockers...which means youll need guideplates...no need to skimp and use stock studs so arp 7/16 should go on..and while your at it pushrods...thats only if you wanna do it the right way though
Old Mar 2, 2008 | 10:27 PM
tspence45's Avatar
Better go ahead and get some new lifters along with all that too.
Old Mar 2, 2008 | 10:34 PM
97badass's Avatar
woot! go $600+ for 10-15 hp
Old Mar 2, 2008 | 10:37 PM
tspence45's Avatar
You'd better just go with some 1.7's for a little extra lift/power. You've got bigger valve covers, with more clearance. So, you shouldn't have to worry too much about hitting.
