belt flew off again
belt flew off again
last night i pulled into a parking lot after a light shower and kicked a shitty lost power steering. i knew right away i'd thrown the belt off got out threw it in the car and wrestled my steering wheel to the nearest socket wrench i put it back on in the rain. the socket wrench is now part of my glove box accessories. my 97z did the same thing when i cut donuts and this was the first one i've cut in this car when i bought the car i but a new gatorback belt on it. is there a solution to this problem?
Only time I ever had an LT1 throw a belt was when I put the wagon windows deep in a snowbank, that was a very differnt problem than this.
If you have had two different cars do it I think it is something YOU are causing,. If it was just one car I could attribute it too some mechanical defect.
[QUOTE=96capricemgr;8859305]What do you think you are going to "upgrade" and what do you think this "upgrade" will get you??
QUOTE]
thats why i ask for suggestions.
QUOTE]
thanks. man throwing the belt off had a snowball effect. put the belt back on but while i was moving stuff around under the hood in the dark i got one of the heater hoses up against the alternator and it put a nice hole in it. car overheated antifreeze everywhere under the hood. replaced the hose. which wouldnt have cost that much but i ended up spending an additional $60 in advance auto parts while waiting around. armor all, tire shine, seafoam, wash n wax, spark plug gapper, magnet on a stick. they need to keep that stuff away from the register. anyway after i got to driving it for awhile i noticed under acc. it bogged down waited untill dark and looked under the hood now i have 3 bad spark plug wires i think it was because of all the antifreeze spraying everything. PITA.
in jegs and summit they have lt1 pulley sets but thats all it says lt1 polished aluminum pulley set it doesnt say what pulleys are included theyre only like $110 in summit but theres no picture either do the sets come with a tensioner?
