Anyone use the Proform Die-Cast Al Valve Covers?
Anyone use these? Do they fit with the Alternator in the stock position? Anyone have any pics of them installed? Proform part number # 141-131
![](http://i94.photobucket.com/albums/l114/nemanracing/pro-141-131_w.jpg)
Any suggestions on any other valve covers to use if these wont fit?
I used them, however I notched the cover for alternator clearance, and welded in a piece of flat aluminum to cover it up. It's behind the alternator, so you can't see it unless you know where to look.
I don't understand why they don't make a notched version in the first place...
Only problem I had with them was keeping the hold down screws tight. Wound up using a drop of blue Locktite on the screws.
I found this over @ camaroz28.com posted on 12-10-2003...
OR you can do what I did....
here are some tips...
![](http://members.***.net/eplanajr/cartech/alternatorgrind1%20tips.JPG)
finished alternator...
this is what i need the valve covers to clear...
![](http://members.***.net/eplanajr/cartech/motor1.jpg)
assembled...
![](http://members.***.net/eplanajr/cartech/motor2.jpg)
![](http://members.***.net/eplanajr/cartech/motor3.jpg)
great pic of assembled view...
![](http://members.***.net/eplanajr/cartech/motor4.jpg)
Heres a few better pics of the passenger side area...
right behind the alterator
![](http://members.***.net/eplanajr/cartech/motor/BZODMotor1.JPG)
heres the gap between the alternator and the valve cover. it is about 1.5mm to 2mm, its more than it looks.
![](http://members.***.net/eplanajr/cartech/motor/BZODMotor2.JPG)
front view of how bad *** it is
![](http://members.***.net/eplanajr/cartech/motor/BZODMotor3.JPG)
side view....
![](http://members.***.net/eplanajr/cartech/motor/BZODMotor4.JPG)
EDIT: Added more pics...
![](http://members.***.net/eplanajr/cartech/alternatorgrind1.jpg)
assembled...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
side view....
I'd much MUCH rather modify an alternator than some valve covers. If I can ever talk my friend out of his LT4 composites, I'll be doing just that. Never know when you might relocate the alt and then have a huge blemish on your nice valve covers!
