cam help needed
Old Mar 13, 2008 | 05:42 PM
kierstyn's Avatar
Default cam help needed
Ok guys i had a good shop that works on lt1 and ls1 cars here local to me put in a cc503 cam. From the cars that i have seen that he has done he does great work! He put the cam in my car and i drove it for a day and the topend started ticking and it lost oil pressure. I took the car back to him he pulled the motor and the cam has eaten the gear off of the oil pump drive. Hows this possible anyone ever had this problem? I called comp they said they havent heard of this problem. He has done this cam in other cars and theres are fine. I just done understand what went wrong with mine. Any help will be greatly appreciated! thanks in advance.
Old Mar 13, 2008 | 05:46 PM
infinitebird's Avatar
sounds like maybe the install was done improperly. I've never heard of that either.
Old Mar 13, 2008 | 05:57 PM
kierstyn's Avatar
I have thought of that to but has done plenty of other cars with no problem.
Old Mar 14, 2008 | 03:10 PM
kierstyn's Avatar
anyone else?
Old Mar 15, 2008 | 09:58 AM
Burning Rubber's Avatar
I had the same problem with mine. And I do not know what could have done it either. I just noticed mine today when I was going to put the motor back together.
Old Mar 15, 2008 | 02:17 PM
kierstyn's Avatar
Does anyone know if you have to run an upgraded oil pump drive gear with these cams? Atleast i know im not the only one thats had this problem! Anyone else?
Old Mar 15, 2008 | 02:35 PM
MadMike 97 Z28's Avatar
this is a problem i have heard a few times. does anyone know what drive gear would be the best to use? im planning on getting cam and dont wont to have to tear into the motor a second time.
Old Mar 15, 2008 | 03:10 PM
kierstyn's Avatar
Mine has turned into a big pain for such a small piece!
Old Mar 15, 2008 | 05:11 PM
Ok I talked to a machinest today and he said the reason why my gear got chewed up was because I had a high volume pump. He said that all the extra volume creates a lot of extra load on the gear and causes the cam to eat up the drive gear. The guy told me to use a factory volume pump.
Old Mar 15, 2008 | 05:29 PM
kierstyn's Avatar
As far as i know mine has a stock pump! I knew about the high flow pump problems. I guess we will play with it some and see!
