Max mill on LT1 cylinder heads...
Old 03-19-2008, 10:33 PM
5.0stang's Avatar
Default Max mill on LT1 cylinder heads...
What is the most you can mill the LT1 cylinder heads?
Are all the combustion chamber volumes the same through the years?
Thanks!
Old 03-20-2008, 07:40 PM
5.0stang's Avatar
Bump........
Old 03-20-2008, 10:10 PM
fuzchunk's Avatar
Default not many peeps answer to a fomoco loose the stang
54cc &ten thou .010 by the book, actual results may differ
Old 03-21-2008, 07:40 AM
96capricemgr's Avatar
What are you trying to accomplish?
I know from experiance that they can go to at least a little over .030, problem is this screws you down the road and you try to build a motor and want to use a flatop with good quench, not the chamber is too small to get the right compression.
Old 03-21-2008, 09:20 AM
96slow6's Avatar
Also as a side note. I to have seen upto .030 but with the impy gasket you need to deepen the alignment plug holes.
Old 03-21-2008, 11:06 AM
mean94lt1's Avatar
mine are .014 so i know you can go that far
Old 03-21-2008, 11:18 AM
96slow6's Avatar
Did your block alignment pins fit into the head ok? If so there is a good general reference. @ .014 they do not need to be machined deeper.
Old 03-21-2008, 12:38 PM
CamaroKid89RS's Avatar
I had mine milled like .018 or .019 when I blew my head gasket so I know you can go that far.
Old 03-21-2008, 04:58 PM
9formula4's Avatar
im going .010" with mine.
The combustion chambers will get smaller.
Old 03-21-2008, 05:42 PM
foggedz's Avatar
Mine have been milled some where in .035 - .04 range. The intake also had to be milled to get the ports to line up.
Old 03-21-2008, 05:58 PM
That is a very good point to make, start cutting heads this much and the intake can not only be missaligned but the intake can bottom out on the ends of the block and not seal properly.
Old 03-27-2008, 10:57 AM
5.0stang's Avatar
I was just curious how much they could be milled.
By shaving it down .03-.04, what kind of effects does this have on the given compression?
Thanks for the replies thus far!
Old 03-27-2008, 05:42 PM
If looking for compression start at the gasket. The stocker is .049 and there are readily available reliable and inexpensive options down to .026. which is like .5 compression gain in gasket alone.
Old 03-27-2008, 07:08 PM
speed_demon24's Avatar
Not sure how much mine are milled, but the intake surface is milled to compensate for that + the head gaskets. Then I had to mill the end rails on the intake manifold since they were bottoming out on the block.
Old 03-27-2008, 08:58 PM
C_Rules's Avatar
just curious how much do you have to mill to lose 1 cc? is there a ratio?
Old 03-27-2008, 10:45 PM
5.0stang's Avatar
Quick question, do the LT4 heads need the LT4 intake to match, or will the LT1 intake work?
Old 03-28-2008, 02:27 PM
The LT4 intake is internally the same as the late LT1 intakes but it has more material above the port to seal to the taller ports in the LT4 heads.
GIZMO posted this pic some time ago and it should help you understand.
http://i85.photobucket.com/albums/k5...1/DCP_1456.jpg
That said the LT4 heads are NOT a particularly good idea unless you are just after being able to say you have them to impress the ignorant.
Old 03-29-2008, 03:27 PM
IronOutlaw's Avatar
mine are milled somewhere around .080. apparently whoever owned the car before me blew a headgasket to and had them shaved extra for compression or someting.
Old 03-30-2008, 07:53 PM
blackz93's Avatar
Originally Posted by 96capricemgr
If looking for compression start at the gasket. The stocker is .039 and there are readily available reliable and inexpensive options down to .026.
I thought they were .049?
Old 03-30-2008, 08:21 PM
You are right, I was thinking about the Felpro, which is .039, I will go back and edit for clarity, thank you.
Quick Reply: Max mill on LT1 cylinder heads...
