egr delete question!!
Old Mar 31, 2008 | 11:42 PM
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
ok well i just looked up some on ebay and why is there 3 of the plates? i thought u only block off 2 holes? anyone know this
Old Mar 31, 2008 | 11:47 PM
I8ASaleen's Avatar
One is supposed to go on the exhaust manifold that you will be replacing and will not need the 3rd one. They have to sell that one just in case someone is not replacing their manifolds.
Old Mar 31, 2008 | 11:51 PM
Storms of War's Avatar
A car won't pass emissions without the EGR and AIR, will it?
Old Mar 31, 2008 | 11:53 PM
i get all of it , the metal pipe goes under the front of the motor right kinda like under the water pump?
and i still dont understand what clip the Solenoid Connector, and put a Vacumn Cap on the Intake where the Rubber Line came off.
what kind of clip?
and what kind of vacumn cap?
Old Mar 31, 2008 | 11:54 PM
i dont think texas does the emissions test does it ? i have no clue
Old Apr 1, 2008 | 12:05 AM
so is it actually worth taking all the egr/air stuff off , besides the clutter in the engine bay? does anyone have their egr/stuff still hooked up on the headers and didnt delete their egr/air
Old Apr 1, 2008 | 12:22 AM
I8ASaleen's Avatar
Yes it's worth it if you don't have to pass emissions. The clip comes out of the EGR solenoid and the lines that go to the solenoid come out of the intake manifold and need to be capped with a vacuum cap. You can even ghetto rig some tape on that small fitting and you'll be fine.
Old Apr 1, 2008 | 07:54 AM
Ok so is it easy to get the block off plates on and to take everything off (egr/air) seriously?
Old Apr 1, 2008 | 07:56 AM
Once I do take the egr/-r off do I have to take the o2's out as well or can Ijust leave them hooked up?
Old Apr 1, 2008 | 08:25 AM
Also since I'm gettin headers and delting my egr/air and o2, where can I get my car tuned at?
And will I have to get bigger fual injecters for the longtubes?
Will my car be running to lean with longtubes?
Old Apr 1, 2008 | 11:09 AM
Where is the vacumn at that I need to take off when I delete my egr/air?
Old Apr 1, 2008 | 11:27 AM
  #32
Pro_built7's Avatar
dude chill out man...
This is SOO easy its ridiculous. OK-
1)block off (with 2 plates) the rear of the intake
2)get a simple vaccuum nipple to plug over the vac. hose that used to go from egr-intake.
3) take off air pump (3 bolts,1 connection) and all associated air tubing (black tubing, chrome tube going to pass. side of motor)
its really that easy..
Old Apr 1, 2008 | 11:29 AM
  #33
Pro_built7's Avatar
http://shbox.com/1/egr.jpg
there you go..
Old Apr 1, 2008 | 11:33 AM
  #34
Pro_built7's Avatar
http://shbox.com/1/air_pump_recall.jpg
  #35
Pro_built7's Avatar
http://shbox.com/ci/AIR.jpg
Old Apr 1, 2008 | 12:14 PM
  #36
YORK_MUSTAINE's Avatar
good pics, some body have real pics of how to.....?
Old Apr 1, 2008 | 01:28 PM
  #37
Ok well is the vacumn the one that's behind the coil pack that's hooked up to the optispark? If so that's not gonna get moisture in the opti?
Old Apr 1, 2008 | 09:12 PM
  #38
I8ASaleen's Avatar
No man, just go out and start taking off the EGR stuff and you'll see where it's all connected and what needs to be taken off. Just do it.
Old Apr 1, 2008 | 09:15 PM
  #39
Highwayflyer's Avatar
Default clip comes out of the EGR solenoid
Does this need to be clipped or can it just be tucked up out of the way and kinda hidden away ? the clip comes out of the EGR solenoid
Old Apr 1, 2008 | 09:25 PM
  #40
the_merv's Avatar
I cut the Connector out of the Harness when I had mine..
Originally Posted by camarostripes96
DOES ANYONE HAVE PICS OF THE WORK BEING DONE OR AFTER THE WORK
Here is mine all done..even with some nice home-made plates.
The Vacumn Port with the Cap on it is the one that you need to Cap. Everything else comes off.
