what is this?
Old Apr 6, 2008 | 03:51 PM
CamaroRacing12's Avatar
Default what is this?
ok so i pulled my pcm out the other night to send it off to Ion at Madz28 for a nice tune.... and i looked and had a random connector unhooked.... i followed it back and went directly to a sensor in the side of the passenger's side head..... anyone kno what sensor this is? i was guessing the oil pressure sensor but i dn....
Old Apr 6, 2008 | 04:54 PM
Ironxcross's Avatar
The plug holds in all the horsepower! CAP IT OFF!
Old Apr 6, 2008 | 10:19 PM
serious inquirys please....
Old Apr 6, 2008 | 10:21 PM
the_merv's Avatar
Veteran: Air Force
Pic.. and color of the Connector?
Old Apr 6, 2008 | 10:23 PM
Ls1Bait's Avatar
^^^Indeed
Old Apr 6, 2008 | 10:25 PM
mhayes2344's Avatar
There's a sensor in the driver's side head for temp...but im guessing since you were on the passenger side of the engine (since you removed the PCM and noticed), you're talking about the passenger side head. Let us know which head, and what merv said.
Old Apr 6, 2008 | 10:27 PM
im digital camera challenged and i wont see my car until next weekend.... but it was under the pcm it was a connector that looked like two plugs plugged into, 1 from each side.... then i followed the wire and it was connected to a sensor in the side of the passenger side head.....
Old Apr 6, 2008 | 11:03 PM
the_merv's Avatar
Veteran: Air Force
Sounds like something someone put in.. I don't remember anything Factory in the Head besides the Water Temp Sensor in the Front Drivers Side..
The EVAP Solenoid is over in that area on top of the Head.. Red Connector.
Old Apr 7, 2008 | 12:45 AM
jb442's Avatar
I believe what you're looking at is the wiring to a fan switch, like the JET Performance Fan Switch. I have the same thing on my car. You install it by removing a plug in the passenger head, and installing a temperature sensor. It's designed to turn both fans on full at a given temperature, I think 195 and off again at 185. It's automatic & no ECU reprogramming is necessary, which is another benefit of the design. If you're getting a tune, it's not going to follow the temp thresholds set in the ECU, but you can easily disconnect it and leave the sensor in the head.
Old Apr 7, 2008 | 01:34 AM
that black sensor in the head closest to you in the picture.... right next to the blue plug boot.... thats it right there... wtf is that for?
Old Apr 7, 2008 | 02:11 AM
Formula350's Avatar
Seeing as THAT guy is running a way aftermarket water pump, I'd say it's his new PCM Coolant Temp Sensor location (the 2 wires are what tip me off). Yours? NOT a clue.
Old Apr 7, 2008 | 02:13 AM
**** it next weekend i will have a pic of it to show u guys
Old Apr 7, 2008 | 02:14 AM
Formula350's Avatar
Make sure to use a flashlight and the camera's flash please And if you take a pic REAL close, put it on MACRO mode so it doesn't come out all nice and blurry
Old Apr 7, 2008 | 06:40 AM
the_merv's Avatar
Veteran: Air Force
That's not even an LT1.. that's a SBC with a LT1 Intake..
Note the Distributor and the Round Exhaust Ports, and the Spark Plugs coming straight out...
That and it looks like an Octopus with all them lines and stuff hangin off of it..
Old Apr 7, 2008 | 07:49 AM
true merv, i didnt look at it closely.... thats just a google image... this friday i'll snap a pic of it
Old Apr 7, 2008 | 09:41 AM
the_merv's Avatar
Veteran: Air Force
I'm not saying your wrong with your question.. I took a close look at that pic and notice some things and threw out some facts incase some people looked at it and were like WTF..
Hopefully we are able to help you out with your question bro..
Old Apr 7, 2008 | 10:16 AM
yea o i kno u didnt mean i was wrong.... i just quick searched LT1 on gogle images and threw up the first pic i saw.... this weekend i'll get a pic of the actual sensor on my car.....
Old Apr 7, 2008 | 10:33 AM
97badass's Avatar
merv you forgot the regular valvecovers too and wtf are those lines coming off the headers???
Old Apr 7, 2008 | 03:30 PM
jb442's Avatar
...for EGT/Pyrometers.
Old Apr 7, 2008 | 04:16 PM
97badass's Avatar
thats what i thought...but damn...didnt think you needed 8 of them
