View Poll Results: Who makes the best LTX heads
Advanced Induction
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
28
29.17%
AFR
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
37
38.54%
Stock Ported
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
19
19.79%
Other
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
12
12.50%
Voters: 96. You may not vote on this poll
Who makes the best head for LTX
Well for one the poll is misleading and falsifying info.
AI DOES NOT MAKE heads, they PORT them. Theres a HUGE difference in porting them and casting them in production.
I agree with 96caprice, the ported stockers are the way to go instead of dropping 1-2k for the heads and then another 1500-2k for the porting, just doesnt makes any sense. I was going to go that way but the pricing was ridiculous after all was said and done so I decided to go with the stockers ported.
should have put it in there and not expect people to read my mind
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Consider the weight, is also a hydraulic roller and went 9.6 with a 1.5 short time, If I had to guess it has probably gone a little quicker he is just delaying posting it because he expects it to run 8s once he gets it(drivetrain) to hold together and hook.
Is a modified LT1 intake too and just 15psi on PUMP GAS. Maybe not the fastest car out there but impressive for all the "handicaps" he places on himself.
Dave J, AI is a Trickflow dealer, buying the Trickflows elsewhere and shipping to them would be a big waste of at least the shipping money.
Here we go with orpples again! That means apples and oranges. The only way to see what heads work the best is to put alll of them on the same car. For instance I have lt4 heads done locally in the Tampa area but I rushed and never did my intake, so if a guy with a similar setup outruns/dynos me with different heads is it the heads or does he have the intake ported? That's one small example. Combo is everything!
you can't compare two lt4 heads ported by a diff guy on diff car's... no two porters are going to get the same result's.. You need to discuss your goal's, and your setup w/ the head guy.. Not folk's on LS1tech or any other car board for that matter...only time you compare is when your doing a TSP package, or any other package by a shop on the board.. you'll even then still see a hp spread...
I Will Give You A Call Brandon. I Had A 408cid Lt1. I Had A Pair Of Ported Lt4 Heads On That Motor I Made 418 Rwhp. I Bought A Set Of Comp. Ported 220 Afr Heads The Car Made 497 Rwhp With A Rich Tuneup No Bs Ask Just Thunderracing.
Are you saying you simply took the lt4 heads off and put the AFR's on and gained 79 RWHP?
#32
but what does it RUN?
I think the poll is showing just how useless the forums can be. The OP has AFRs and is questioning that decision yet AFRs which are a tiny minority of what is used are doing well in the poll.
Betting you have a bunch of kids with stock cars voting
based on what they read in magzines.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Stage 3 port, polish and coat
Hot Cam
Long Tubes on stock exhaust
A4
370RWHP 350RWTQ
answer your question?
#33
#35
#36
Check the flowrates
http://www.pm-fl.com/catalog/flowshe...3eef0e98fea51e
#38
I'm dumping all my $$ into getting it ready for some HDPE track days so I doubt I'll get to the drag strip anytime soon.
