"Stock Internals" Build
Could this be done on a daily driver application, I suppose its find for a HR since your using the stock cam.
Any downsides to this?
I have blocked the returns on every LTX race motor that I have ever built and have never seen any kind of wear or failure as a result. That is with both stock lifters and modified stock lifters (both at over 7000 rpm).
The stock LT1 oil pan was replaced with a 1997 Vortec truck (5 quart) with the baffle removed. We will only be running 4 quarts of oil. The extra pan capacity will reduce windage.
The front cover had to be slightly clearanced for the timing chain.
Note that the stock push rods were replaced with chrome-moly ones from Comp. The rockers are adjusted to one turn past zero lash.
IMO those preaching no preload find it works better because the valvetrain is out of control and more preload just means more float, they take away all the preload to reduce the height of the float.
Should be noted tht thread count on the studs affects the preload for a given amount of turn. 7/16" studs have fewer threads per inch than 3/8" so one full turn on a 7/16" stud is more preload.
Off topic. I am in town this week and should actually get your fuel rails done.
When I am an old man (50's) young people probably won't even want to be associated with me any more!!
Take Care,
Daren
What are your plans for an opti?
