"Stock Internals" Build
Old Mar 30, 2009 | 11:57 AM
  #141
Speed Density's Avatar
hashtagBMW
It looks like he is since the IAT has a bracket right before the TB.
Old Mar 30, 2009 | 02:00 PM
  #142
chrs1313's Avatar
Yeah that is what I thought too…I am an engineer for an air filter company and thoughout our testing we found that if you add a cone shaped funnel(tornado style) to the end of a pipe(or in your case a tb) you can increase from anywhere from 20%-30% for the same engine pull or load…(in our case a huge regen blower)…
So if we attach a 2” pvc pipe to the regen blower and set the VFD to a specific value of say 60hz if we can get a CFM value of say 500CFM through the 2” PVC pipe, if we were to duplicate the same setup with a cone shaped funnel on the inlet end of the PVC pipe and everything else being identical, we can now flow 650CFM through the PVC pipe…the best shape that has the least restriction though a pipe is a tornado like funnel shape…
So an idea might be to get an airfoil on the throttle body and possibly make something out of fiberglass to slip on the throttle body that resembles a funnel, doesn’t have to be big just have a nice smooth radius…
I will pm you a picture of what I mean if you like…
Old Mar 31, 2009 | 06:33 AM
  #143
GIZMO's Avatar
The throttle body has to be bone stock. We can run it open or run the factory duct work. Nothing aftermarket or fabricated is allowed.
Old Mar 31, 2009 | 07:03 AM
  #144
chrs1313's Avatar
okay gotcha...good luck with the build cant wait to see the track results and photos...
Old Mar 31, 2009 | 09:22 PM
  #145
GIZMO's Avatar
I am looking for a stock LS1 air box and duct work for a 1998-2002 Ram Air T/A. Must be in mint condition.
Old Apr 8, 2009 | 01:33 AM
  #146
2001ws6-500hp's Avatar
i have a stock air box, does it matter if it has a k&n sticker on it?
Old Apr 8, 2009 | 05:10 AM
  #147
GIZMO's Avatar
Thanks for the offer, but I have already found one.
I do need the bellows/duct that goes on the throttle body on Ram Air LT1 cars.
Thanks,
Daren
Old Apr 19, 2009 | 08:41 PM
  #148
05chevyguy's Avatar
looking forward to seeing this finished and running!
Old May 3, 2009 | 01:19 PM
  #149
GIZMO's Avatar
After a week on the Disney Magic and two weeks work in Honduras I was finally able to get back and work on the car with the kids. We don't lack much now.
Bleeding the brakes.
Caleb working the peddle (Check out the new Grant steering wheel).
Old May 3, 2009 | 01:39 PM
  #150
CamaroRacing12's Avatar
loooking good!
Old May 10, 2009 | 08:38 AM
  #151
GIZMO's Avatar
The kids came over and worked on the interior Tuesday.
Installing the carpet.
Harness.
Testing the seats.
Can you tell that they are getting excited?
Old May 10, 2009 | 09:16 AM
  #152
Razor_Blade's Avatar
I've been following the build and I'm getting exited to! How long before you start doing shakedown runs?
Old May 10, 2009 | 02:37 PM
  #153
Puck's Avatar
She is coming along nicely. Can't wait for the first runs.
Old May 10, 2009 | 04:32 PM
  #154
mean_greenZ's Avatar
i saw this thread and sat down and couldn't stop reading! this is a great project! i wish i could start something like this where i live. if y'all make it to shadyside some i'd love to come watch!
did you use speed pro hypereutectic pistons? what rods?
oh...and how does that fit with the rectangle header ports and the D-shaped head ports?
Old May 10, 2009 | 06:01 PM
  #155
SoxXpupPeT's Avatar
looks real good. when do you think shell be 100% finished ?
Old May 10, 2009 | 07:05 PM
  #156
GIZMO's Avatar
Today they installed the new aluminum Driveshaft.
Shift linkage and new deep transmission pan.
Jason and Caleb.
A cool photo!
We hope to get it running this week.
The pistons and rods are the ones that came in the motor (Mahle/GM).
Old May 10, 2009 | 07:45 PM
  #157
Puck's Avatar
Is that the spohn 25mm rear sway bar? I run that as well and LOVE it. Cured a slight pulling to one side on launch that I had with the factory piece.
Old May 10, 2009 | 07:57 PM
  #158
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
When you say, "Deep" you really mean it. That's one deeeep trans pan.
Old May 17, 2009 | 08:01 AM
  #159
GIZMO's Avatar
We finally got it running yesterday!
The Painless fuse/relay assembly gave us fits. Over half of the pins were installed in the wrong slots by the factory. Once we fixed that everything worked including the electric windows! She fired on the first hit too!
Lots of tuning to do.
Old May 17, 2009 | 10:31 AM
  #160
SoxXpupPeT's Avatar
Congrats! to you and all the kids doing the work! to finally have something start up like that feels amazing!
if i were you id give painless a call and complain simply because thats bs. but at least you were all smart enough to figure out the problem and correct it. get some vids of that beast running now!
