Urgent need Help on Timing Cover
Old Apr 29, 2008 | 09:28 PM
TAEnvy's Avatar
Default Urgent need Help on Timing Cover
hey guys. Im putting a cam in my car and I removed all the bolts from the oil pan so I dont tear my oil pan gasket but it seems like the gasket is glued or something to the timing cover. Is this common? How do I get it off without tearing it?
Old Apr 29, 2008 | 09:32 PM
Speed Density's Avatar
hashtagBMW
Is it a paper gasket or rubber?
Just try to massage it a bit and see it it free's itself, if that doesnt work get a knife and pry it off.
Tony.
Old Apr 29, 2008 | 09:38 PM
TAEnvy's Avatar
its rubber
Old Apr 29, 2008 | 09:44 PM
hashtagBMW
You should be able to get it off then, I had the same problems with my stock shortblock. Just be carefull not to rip it.
Tony.
Old Apr 29, 2008 | 09:46 PM
TAEnvy's Avatar
dude Raichu #26 was the best pokemon. A close second to wartortle, haha.
Old Apr 29, 2008 | 10:15 PM
SS RRR's Avatar
Village Troll
You can try to pry the tube of a WD-40 can and "inject" it, but yeah just be careful when prying it off. I have ripped them before, but was able to keep it from leaking by using permatex ultra black. Basically if you rip it it's not the end of the world. They key is to make sure after applying the sealant to the crack(s), let it cure completely before starting the engine.
Old Apr 29, 2008 | 10:28 PM
TAEnvy's Avatar
YESSSSSSS I did it without ripping.
Now There is something covering the crank gear of the timing chain, since mine is a 97 im guessing its something to do with the cps which im deleting, but how do I take it off.
I dont have a gear puller but will a pitman arm puller works, its pretty much the same thing.
Old Apr 29, 2008 | 11:44 PM
MadMike 97 Z28's Avatar
just pulled mine off with a puller about 30 min. ago.
Old Apr 30, 2008 | 04:07 PM
SS RRR's Avatar
Village Troll
Has the timing chain and gears ever been replaced? If not then you should and that'll require a puller to take the crank gear off the crank. I haven't tried it but the arm puller may work for both the crank reluctor ring and the timing gear. The reluctor should easily come off once you get a little tension on it.
