LE3 with supercharger possible?
Old May 9, 2008 | 11:07 PM
RaM AiR 97's Avatar
Default LE3 with supercharger possible?
My question is how much psi could i actually get into the motor. if i do i am thinking of making it a 355. sombody please give me opinions or how should i go about it. What brand of supercharger would be good or what ci.
Old May 10, 2008 | 12:20 AM
1redta's Avatar
Default hjkl
the LE3 heads will flow very well with FI as long as you get an appropriate cam. You will need to watch your compresion ratio. the fuel system will be very important also, you can search for a similar set up. Make sure the bottom end is sutable for the horsepower level you are looking to achieve. ATI seems very popular ( no experience myself ) as long as you get a D1
Old May 10, 2008 | 02:02 AM
daniel6718's Avatar
forged rods and pistons with stock crank will live to over 1000 if done right...cubes id so a stock cube...no need to bore out a good block...but you can...put the biggest charger you can
Old May 10, 2008 | 06:29 PM
RaM AiR 97's Avatar
So you guys think i should go with the stock CI. ATI,paxton,vortech??? So its all up to cam selection would you guys think that i would have to have a custom cam. What brand of crank pistons and rods do you guys recommend.
Old May 10, 2008 | 07:21 PM
383lt1impala's Avatar
yea u can go stock ci but i strongly advise u to go with a procharger. due to their customer service and their products are the best!
Old May 10, 2008 | 10:57 PM
RaM AiR 97's Avatar
383lt1impala have you bought a procharger. What power gains did you get from it? Was it a moded engine or stock.
Old May 10, 2008 | 10:59 PM
RaM AiR 97's Avatar
8 psi w/ P600B or P-1SC 55-60% 2 Core
10-14 psi w/ P-1SC 65-85% Twin Highflow
12-20 psi w/ D-1 or D-1SC 75% Twin Highflow
4.5-15 psi H.O. Kit w/ P-1SC
wich one would be best for a LE3 package
Old May 10, 2008 | 11:01 PM
James Montigny's Avatar
Nothing wrong with using LE3 heads, just be sure to get a cam set up for a blower
not the standard N/A grinds. They should be able to substitute that at no extra charge.
Procharger makes very nice blowers, you will not be disapointed.
I drool over their intercooled setups on a regular basis LOL
I think I will go that route on my next build.
Old May 10, 2008 | 11:11 PM
RaM AiR 97's Avatar
so lloyd should make a custom for me based on the psi which i want to throw at the motor.
Old May 11, 2008 | 07:31 AM
Yes, Bret Bauer does the cam design for Lloyd.
Every LE setup comes with a custom cam.
The standard grind just happens to be set up for N/A applications (lots of overlap) which is
not at all optimal for a forced induction setup.
If you tell Lloyd what you are doing and what your goals are, he'll make sure
you get an appropriate cam Do be sure to note what your bottom end
looks like as well since it will help determine how high you can rev.
- James
Old May 12, 2008 | 10:47 AM
Bad_tx_Z28's Avatar
that setup should make some nasty powah! i have always thought about doing a FI build but never made up my mind.
