burning oil
i have been suspecting that my car might be burning a little oil. it hasnt been doing this long because in my exhaust video i posted in the vid section a while back, you can see that it didnt do it at all. although sometimes i would smell it. but tonight me and my friend were messing around and i got on it pretty hard, i dont beat on it all the time just some spirited driving now and then, so i looked back and there was a huge cloud of blue smoke trailing me for bout a half mile back.
so that was the answer to my suspiscion. i havnt looked to see if it does it while im revving it or when i crank it up. so is it worn out rings or valve seals? i have 141k on it btw. this sucks so bad cause now i cant do anything in it w/o it smoking and looking like some redneck truck
I am also loosing oil out the back of my IM as there is a gasket back there thats annoying but thats something else.
Anyway even replacing the PCV Valve, putting in a PCV on the Passenger rear elbow to the TB did not completely stop it its a hell of a lot better... and I also have a gray fuel cloud sometimes since i have not gotten a tune yet... but anyway point being you probably will have to get a catch can as I went ahead and did, run it in line on the PCV system and it should handle the IM oil problem. Then you should see an end to it.
But I feel your pain, trust me... it scared the **** out of me when it started and I thought it was rings to as it would never do it on start up or normal driving.... just when I nailed it.
You can find a good catch can with a level indicator and a drain plug in the bottom thats one sealed unit for 29.98 on eBay shipped. Makes life easy when you want to drain it just grab an old oil bottle and your done.
Hope this helped!
how high should it read to be "normal" on the compression check?
Either way your def higher in miles i am not even at 5k. But I have the same issue as I said. And I highly doubt its rings when I keep finding oil in the IM.
But either way good luck with it.
Do not expect a new PCV to fix it get a catch can and clean out the IM with carb cleaner then let it dry a few hours. I bet it will take care of the problem as it does for most everyone else on the boards.
i haven't gotten a chance to get on here in a few days. but anyway i bought a new pcv valve and got a small breather filter to put on top of it. and capped off where it ran into the TB. i hammered it twice today and no smoke! thank goodness no big unexpected expense!
