Electric Water Pump... Need some help
thanks again
* remove water pump
* remove inspection cover
* press out impeller and bearings
* install freeze plug
* re-install water pump housing
* install electric pump
* trim fan shroud
* hook up electrical connections
That's it. I suggest wiring up a safety block with LED and/or Piezo buzzer
to warn you if the ground goes bad or the pump fails.
* remove water pump
* trim fan shroud
Not sure what brand you are going with or if this helps..but take a look.
http://picasaweb.google.com/calder.c...37224064474370
Yep..... That sucked. Car ended up being stolen by the tow truck driver AAA sent to.
Anyways I wired in parallel with the water pump circuit a bright *** led right into my a pillar I also put in a second circuit in case the fuse blows with a switch to my dash so I dont even have to pull over if the light goes out and its not a major issue
