Ram HDX Clutch
I'm running one with a SPEC aluminum flywheel. It chatters alot if you don't bring up your rpm's first and just let it go. I've had the set-up for 2 years with no other problems and still grabs real good.
Thanks guys, Yeah it's just a bolt on car will mostly stay that way. I had a Mcleod clutch in it and it's dead not really sure what happened to it. it only had about 3-5k on it.
Yeah were you working at now Rocket?
BTW I have a Ram Powergrip hopefully going in in a few weeks when my S60 shows up.
Good man, I have the same clutch I've had it since last September and am really happy with my choice. The only think I can't quite explain is why sometimes its dead silent and others its a chattering bastard and a half Most of the time it doesn't chatter much at all though. I wouldn't listen to RAM about not breaking it in though. A lot of guys don't and they work fine, but it seems like those who do give it a break-in end up with less chatter. Then again that could be completely coincidental so its really up to you. I put 80 miles on mine then did a dump + big *** peel out to make sure it wasn't slipping at all. Probably not the brightest thing I've done in my life but oh well
