Lloyd Elliot or Advanced Inductions
This starts to touch on the age old argument where a good set of ported cylinder heads/stock cam will always outperform a larger cam/stock heads application (I don't mean just straight line performance). I believe it, just because of what needs to be done to a cam only application in order to take full advantage of the new power curve.
Researching, I found most people with the AI190 kit feel the same.
I have been using Lloyd's stuff for six years now.. Curently running 10s N/A as are a few with Phil's stuff
Both good products IMHO
I think you misunderstand pumping losses and engine physics.
Jes
Advanced Induction gets my vote.
A lot of the "this is the way it will be" comments like the lack of torque and such are based on information gathered from the average poor combo.
Of course tuning by ED Wright helps tame a big cam in a smallish engine.
Oh, and I have more low end torque than my tires can cope with.
Mike
Alek is running a SR too, so that definitely doesn't hurt his cause.
Jes
I don't know what you mean about "some heads that do..." but that's neither here nor there. What I do know is that when you compare a 190 to 200cc head you WILL NOT experience torque loss of any kind.
2. this has been argued/discussed countless times.
3. Both can do great work and have had proven results
4. Ideal choice depends on your setup/goals/budget/priorities
5. Neither one is "better", each has their supporters and detractors
