Lloyd Elliot or Advanced Inductions
I believe I will be ordering a set of those over the winter.
Just remember, bigger aint better unless it wasnt big enough to begin with.
There are not that great a differences between the same casting of head that it would need a drastically different cam based on the heads alone.
Very Much So.
It's the same ol' stuff when this discussion comes up.. Same guy's come on here, Rep AI, all day, claim they have the fastest car's, LE Guy's have the most HP, but in the end it's upto you to go with whomever tickles your fancy.. both are great companies w/ happy customers.. So half the equation is outta the way already... Good luck on your choice.. Let us know how it work's out...
Both the heads and cam have to complement each other as far as how much air the cam is trying to pull in vs how much the heads are allowing. If you don't have a combo that works well together, you're not going to make much power.
That said, I agree that its better to go more all out on the heads than the cam.
