ignition problems
Old Jun 28, 2008 | 03:20 PM
That_guy's Avatar
Default ignition problems
yea its been awhile lol . well its been months since the lt1 was driven, like 3months well i tried to turn it over today so i can drive it to the back . it turned over but didnt turn on . i did it again but this time it didnt turn over ya know to the point where you can hear that clicking sound. This is what i think is wrong with it
opti finally went out
spark plugs
so give me some opinions
Old Jun 28, 2008 | 03:57 PM
Mojave's Avatar
Sounds like a dead battery if the starter solenoid was just clicking.
Old Jun 28, 2008 | 04:14 PM
I8ASaleen's Avatar
Ummm...dead battery. When you don't start a car in months and you leave the cables on it the car will drain the battery over time.
Old Jun 28, 2008 | 07:11 PM
That_guy's Avatar
But The Battery Was Fine The Lights Came Out And Everything.
Old Jun 28, 2008 | 07:20 PM
Speed Density's Avatar
hashtagBMW
Your lights dont draw as much power as starting a vehicle.
Get a charger on it and try again.
I8ASaleen's Avatar
That may be true, but think about it, the starter takes way more voltage to crank over than a tiny overhead light.
Old Jun 28, 2008 | 07:25 PM
That_guy's Avatar
i see what you are saying cause it turned over a bit after my grandpa charged it overnight lol i just got that battery so basically it needs a new battery.
Old Jun 29, 2008 | 07:44 AM
That_guy's Avatar
Any Other Options
Old Jun 29, 2008 | 08:01 AM
leadfoot4's Avatar
Originally Posted by That_guy
Any Other Options
First, you need to get the car to a point will it will crank over a sufficient number of times so it will start, assuming, of course, that nothing is wrong. Once you reach that point, you can then trouble shoot.
When you first tried to start it, did you hear the fuel pump kick on? Did you give it a moment of running, so it would build up fuel pressure? If it hasn't been started in quite a while, it will take 10-15 seconds for the pump to get the fuel lines up to pressure.
You say, "I just got the battery". Do you mean it's fairly new? If so, just let it charge for a while before you try to start the car again. You might be OK...
Old Jun 29, 2008 | 01:11 PM
I8ASaleen's Avatar
I'm with this guy. The fuel pump will sound like a click when your put the key in the on position - just wait about 10-15 seconds and then try to start it with the new battery. Let us know how it turns out.
Old Jun 29, 2008 | 03:18 PM
That_guy's Avatar
i do hear the fuel pump and the battery is new i got it 3months before i gave it to my uncle then he drove it for 2months and its just been sitting at my grandparents house. But maybe i need a new battery. On monday i will try the things you guys suggested and see what happens
Old Jun 30, 2008 | 05:35 PM
FactoryLT1Freak's Avatar
hey if your looking for a set of heads to replace the cracked one. i live about 5 mins south of you. i have 2 spair sets. hell and a hot cam if you would want to throw that in too. but on to the problem. if you indeed do have a cracked head then i would start worring about fixing that before you run the engine possible messing even more stuff up. oil and coolant mixed together equals very bad things. hit me up if you want the heads. good luck
