4L80E into LT1
Even so the BFH is a nessessity. As is some expensive electronics to make the PCM happy. I'm not sure what the current trick mod status is on this, but if I recall correctly the first 4L80E used a stand-alone computer tapped into the VSS signal while the LT1 PCM used a manual tranny program to avoid any tranny control issues. But its been years since I read that thread.
Might be a good mod for a Duramax swap though. :p
Ordered a Midwest Fab 9 so the driveshaft will be here shortly.
So if I drop back to a 3.73 gear with the turbo 350 I dont think it will be that bad to street drive. I drive it a good bit on the street.
Anyone have any input here? As to rpm differences in overdrive with a 4.11 vs a turbo 350 with a 3.73 gear, same 28 inch tall tire?
With the Turbo 350, 3.73 gears, and a 28" tire it would turn about 2900 at 65.
edit: If you are going with a non overdrive transmission just get a 400 with your power levels.
Here is the gear ratios of the trannies
http://www.tciauto.com/Products/Tech...ear_ratios.asp
This one works, but there is one with an Excel spreadsheet that shows everything at every RPM level, pretty cool.
http://www.f-body.org/gears/
