Which Distributor...if Any... Would Best Fit A Machined Lt1/lt4 Intake Manifold??
The Motor Is Not Set Up For Opti.....was Dynoed With Single Plane And Old Style Dist. I Cant Afford Single Plane Yet, So I Want To Machine My Intake To Take An Old Style Dist.
Hope This Is Specific Enough...i Seem To Always Post Messed Up Threads Lmao
Thanks Yall
Thanks Yall
Back when I was going to go rear mount this is the one I needed to clear the cowl
http://store.summitracing.com/partde...5&autoview=sku
Ok Thankis Alott Im Checkin It Out Now
Damnit I Knew I Forgot Something Its Going In A B Body, It Might Be The Same Amount Of Space But It Doesnt Seem To Be The Cowl Im Worried About, It Was The Spot Where The Egr Tube Went....on The Actual Intake
I didnt get to far into it as this was my first engine build and I sold it to buy my transam before I finished it.I had picked the setup off of one of the guys in my club locally Though I do have some pics of it
if that gives you a better idea of the clearance
Oh Ok, Well Ya I Can Kinda See I Think That Would Be Alright But Ill Probably Look At The Dimensions And Check Mine Out It Sure Looks Tight Between There And Tha Back If Tha Bread Box Thanks Alott Tho
Because Mike Put Some Lil Cover Over The Cam...i Could Remove It But Idk.. Also If I Run Opti I Need To Go And Change It Back To The Lt1 Timing Chain Its Got Another One On There Now. When It Was Just Freshened Up It Was Set Up Like That...thats Tha Way Its Makin Tha 698 Right Now. So I Was Just Kinda Gonna Go Like That Im Still Not Sure.
Ive Been Lookin For A Cheap Manifold So I Can Atleast Run Single Plane Carbeurated
I Can Use Any Sbc Manifold Right....they Just Have To Re-machine The Holes???
Thanks, Zach
Thanks, Zach
i have no idea, but thats what he said when we were talking about it when i picked it up.
i got tha opti, gear, and chain. i could swap it out, and its sounding more and more tempting to do. but i think that motor will be limited by tha computer even after tuning. maybe not idk more input is always welcome how high can a stock computer (tuned) rev?? does the opti itsself have a limit??
thanks again yall
thanks again yall
Damn, that distributor in that pic is huge.
I'll try to get the model number off mine. The cap is way smaller. I have a crank trigger and running a FAST computer.
good luck
John
good luck
John
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
get the msd crab cap style of distributor! just my 2 cents.
i ended up running a stock GM vortec distributor from a 95-97 pickup the msd unit is much cheaper!!!!! live and learn
