True Duals WTF!!!
Thanks Calvin
to your question, maybe you need an LT4 Knock module?, but that wouldn't make any sense if you think its faster up top.
you feel like you are losing power because you are losing back pressure. which is probably giving you a few more hp but the same or maybe a little less tq.
now, to remedy this problem... cam it
I say put a decent tq convertor (like a 3600ish yank or precision) to take advantage of the new rpm range and don't look back.
On a side note, did you take any pics of your duals? I'd like to see them if you did...
btw, I'm from wichita, and I was at the LTxshootout too
You definately need to go to the track! If you did lose power you may have a miss caused by burned wires,been there done that..
