hey guys i want yalls openion on how to build my moto because this will be my first motor build.
first im on a budget
and my dad and i are doing all the work ourselves (me and my dad are both mechanics)
i have a 1997 camaro ss
M6
LT1
150,000 miles
Wants:
good rwhp
dependability
to pass emmisions
Dont Want:
i dont really want a lopey sounding cam because i want it so sound stock
ok this is what i need help deciding
LT1 convert to an LT4?
port heads?
port intake?
throttle body? 52mm 54mm 58mm
cam? (no lopey sound)
crankshaft? (stock?)
connecting rods/pistons?
barrings?
lifters?
pushrods?
rockers?(stock 1.5 or aftermarket 1.6 roller or stsmped steel)
Tune?
headers? Y-pipe?(rember i need to pass emmissions)
is an electric water pump worth it?
it would be greatly be apprecated if yall could help me out on this
thanks
Michael
M6
LT1
150,000 miles
Wants:
good rwhp
dependability
to pass emmisions
Dont Want:
port heads?
port intake?
barrings?
lifters?
pushrods?
Tune?
thanks
Michael
Keep it just the way it is (stock motor no rebuild) and add nitrous. It's all the qualities you listed that you'd want in the build. This is of course assuming that you were going to be rebuilding a motor that isn't broken. Obviously if it's already broken then you have to rebuild it.
I would do a bore and hone 30 over, align hone, square deck, recondition the crank and rods (or upgrade to aftermarket forged internal is you want), 4.03" pistons (your choice)...the whole nine yards. End result will be a reconditioned 355. If you are going for an emissions build, odds are that you won't be making insane horsepower so you can get away with a stock rebuild and not forged.
Port the stock heads, port the stock intake manifold, 52mm or 58mm TB, LT4 hot cam kit, cc 1.6 rr's, shorties, catback of your choice (I like Magnaflow).
This should net you a healthy reliable motor with a bit more grunt than stock, emissions legal too.
If you want a cam that sounds like stock, drives like stock but has more power I can recommend you the LPE211
im surprised it hasnt been brought up yet, but as far as a cam with little to no lopey idle you should go with the crane 227, it puts down some damn impressive numbers too.
For headers you can do Long tubes with a catted Y, look for a FLP set up with the 94-95 smog fittings. Are you in Brazoria or Fort bend county?
Quote:
-No.
port heads?
-Yes, there are tons of shops in your area that can do a good job w/ this.
port intake?
-Gasket match
-put a 52 on it while you're there.
-Unless yours is messed up stay stock.
-Keep the stock rods, get new bolts, look in to SRP pistons, try to bump the compression up to 11.
barrings?
-machine shop will replace these when you take them the block.
lifters?
-unless you're having issues they should be fine.
pushrods?
-after you get the work done figure out what length you need and order a set
-look into the comp magnum rockers, self aligning.
Tune?
-surely someone in houston is tuning these.
-you should only have to pass the OBD2 test, tuner should be able to take care of that, you can run long tubes w/ a y and a cat if you want and have them tune out the air pump.
-only if you don't have a new pump in the last 2 yrs.
Pics of car?Originally Posted by 97camaross
LT1 convert to an LT4?-No.
port heads?
port intake?
-Gasket match
barrings?
lifters?
pushrods?
Tune?
just keep it simple, you're expecting to get a small cam, get a decent converter to match it, gears too. you'll get more out of a mild motor if all parts work together.
I use HEB on shaver for my engine work, jeff's a good guy to deal w/.
Quote:
ya im in pearland. why?Originally Posted by BizZzatch350
For headers you can do Long tubes with a catted Y, look for a FLP set up with the 94-95 smog fittings. Are you in Brazoria or Fort bend county? Quote:
ya ill get some picts soonOriginally Posted by bigbadblack93z
Pics of car?just keep it simple, you're expecting to get a small cam, get a decent converter to match it, gears too. you'll get more out of a mild motor if all parts work together.
Quote:
I'm from Houston, figure Brazoria county would be a lot easier to get a sticker in then Ft bend would be. But your OBDII, just keep it passing visual and plug in and your good to goOriginally Posted by 97camaross
ya im in pearland. why? http://i84.photobucket.com/albums/k2...8/SANY1463.jpg
http://i84.photobucket.com/albums/k2...8/SANY1461.jpg
http://i84.photobucket.com/albums/k2...8/SANY1469.jpg
http://i84.photobucket.com/albums/k2...8/SANY1459.jpg
here are some picts im gettin it painted in 2 weeks
