What is this problem??????
Old Jul 28, 2008 | 05:25 PM
Kmaroman's Avatar
what vaccuum line shoudl be at 45 lm97z
Old Jul 28, 2008 | 05:29 PM
Kmaroman's Avatar
http://shbox.com/1/vac_check_valve.jpg i tested the vaccuum line in the picture the one on top of the, vacuum check valve it was at 19 to
Old Jul 28, 2008 | 05:56 PM
Kmaroman's Avatar
i took for a drive up and down the road and if i put it in 4th at 35 it and mash it it just studder's cutting in an out and run's like crap however. If i from a dead stop and take off it doesnt studder at all
Old Jul 28, 2008 | 06:52 PM
Kmaroman's Avatar
**** it, i'm taking it to the garage
Old Jul 28, 2008 | 11:54 PM
LM97Z's Avatar
Hey, i just got off work, i'm sure i can walk you through this, Now, that pic you showed doesn't look like the reg., that valve has something to do with the evap. canister. The reg. is in the back RH side behind the intake on the fuel rail, here are a couple pix i took for you in my book, the first pic shows where its located (notice how i mark with a marker), the next pic shows it as its on the fuel rail, you will notice the vacuum port on the end of the reg. canister, if you look to the right of this pic, you will see where the pressure valve is where you hooked up the pressure gauge, as you can see, they are close to each other, i want you to check FUEL PRESSURE with that vacuum line disconnected from the regulator, let me know what it reads at idle & reving it up.
Old Jul 29, 2008 | 12:47 AM
97lt1camaro's Avatar
I just performed that test on my car. Key on primed, 0 psi. Prime 6 more times, roughly 8 psi. I attempt to start it, it slowly comes to life bouncing around from 15-20 psi then finally fires and idles at 46 psi. Guage taped on window and WOT yeilds it dropping to 25 psi, as soon as the car is turned off, 0 psi. Yay new fuel pump!
Old Jul 29, 2008 | 06:52 AM
Kmaroman's Avatar
My fuel pressure stay's at 42psi revving up it stay at 42psi to. Btw since my car's a 93 and the fuel rail is different my regulater was on the passenger side of the manifold. I'm going to post a pic up and see if you happen to know what it is cause i don't have a clue it did have vacuum line's hooked up to it though
Old Jul 29, 2008 | 07:15 AM
Kmaroman's Avatar
the yellow line's are the vacuum lines the one with the arrow farthiest to the left is the one coming from that port on the driverside of the intake manifold the other one is exiting the thing. The little box there hooked to says delco remy on the side
Old Jul 29, 2008 | 07:21 AM
Kmaroman's Avatar
i also took the car out for a spin with that port unhooked ran fine. I took it for another drive with it hooked up ran fine to. put it in a gear that would bog the motor down got on it and it didn't sputter or miss out none. It ran fine both way's but while setting still the car still idle at 750rpm if i was in netreul and the car was moving 30 or 40ish it stayed idling at 975rpm. The first time i test drove it with the hose unhooked it did idle roughly but evened out after a few second's. But otherwise then the low idle it's running good again
Old Jul 29, 2008 | 07:46 AM
Kmaroman's Avatar
the wierd thing is my car is just idling low it's not all choppy and bogging just low i mean 750 is low ain't it
Old Jul 29, 2008 | 12:34 PM
Kmaroman's Avatar
bumped
Old Jul 29, 2008 | 08:25 PM
  #32
Kmaroman's Avatar
bump for Z to see
