4.10 daily drivers?
Old Aug 15, 2008 | 12:13 AM
HoLLo's Avatar
Default 4.10 daily drivers?
Who here daily drives a car with 4.10s? What gains can I expect to see with 4.10s on a full exhaust/intake LT1? How much worse is highway mileage? I get about 260 miles to a tank on average, i'm curious to how that might change if anyone has any input on this I appreciate it.
Old Aug 15, 2008 | 12:25 AM
kinglt-1's Avatar
you will be at 2000 or 2200rpm(can't remember which) @ 80mph in 6th. Prolly loose a little mpg, maybe 20mi on a tank?
Old Aug 15, 2008 | 12:36 AM
Zeevo's Avatar
I have 4.10s in my daily, and last fillup I netted 27mpg (mostly interstate, some highway/curvy roads). I average ~24mpg driving on our curvy TN roads, mainly due to the fact I can get up into 6th at 47mph. I have gotten up to 31mpg on long trips with 3.73s, but I havent went on many long trips with the newer gears. This is all with the shorter geared M29 T56.
Old Aug 15, 2008 | 12:51 AM
Fixxer99TA's Avatar
You wont loose much on gas mileage, unless you cant stay out of it after the install
You still have 6th gear, which will always help the gas mileage. Daily driving it your just going to have to shift more, that would really be it. Oh, and lay into it more....
Old Aug 15, 2008 | 07:15 AM
Camminaro's Avatar
Well I cant chime in with experiance with a LT1...but I did DD a 00' GMC shortbed reg. cab with a 6.0 for about 2 years with 4.10's. And it was the best decision I ever made. Fuel milege actually picked up around town because it could cruise easily in OD...not bogging. And I saw no differance on hwy milege...I say go for it. I have 3.73's in my Camaro now that I DD....and its a A4
Old Aug 15, 2008 | 07:22 AM
blackz6sp's Avatar
My in town driving actually picked up mpg with the 4.10's.
Old Aug 15, 2008 | 08:45 AM
HoLLo's Avatar
So, most would agree 4.10s on a DD is a wise decision?
Old Aug 15, 2008 | 08:50 AM
1995Transamconvert's Avatar
How about with an A4?
Old Aug 15, 2008 | 09:03 AM
HoLLo's Avatar
I'm looking at the Motive 4.10s. and the installation kits. Which one of these installation kits do i NEED to have?
* Basic Kit: Includes pinion shims, crush sleeve, pinion seal & cover gasket
* Complete Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, and pinion & carrier bearings
* Deluxe Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals. (All of the small parts and pieces necessary to RESTORE an axle to like new condition!)
Old Aug 15, 2008 | 09:11 AM
954mula's Avatar
You will NEED the basic. Whether or not you get the others depends on the condition of what you have. I'd get the complete but that's just me.
Old Aug 15, 2008 | 09:24 AM
Bad_tx_Z28's Avatar
i DD 3.73's inmy A4, i noticed a lil drop, but im getting ready to swap to a t-56
Old Aug 15, 2008 | 09:34 AM
7camaro7's Avatar
Darren told me to make sure to #1 not buy used gears and #2 to try to get GM.
I'm going to 410 mine too when i get the cash. It'll probably be next year. I want those probably just before my cam swap.
Old Aug 15, 2008 | 09:39 AM
tbird31's Avatar
yea do it. you'll never look back.
Old Aug 15, 2008 | 09:43 AM
dankl's Avatar
I did my rear-end swap a few weeks back. Moser 12-bolt with 4.10's. I love it for my DD. Gas mileage doesn't seem to be affected much. Just using 6th gear more in city driving now.
Be careful putting money into that stock 10-bolt though. I was contemplating the 4.10's on my stock rear, but decided to just upgrade the entire rear. Figured less of a chance to develop a gear whine and also much less of a chance of destroying those gears.
4.10's and the 10-bolt don't go well together...
Old Aug 15, 2008 | 09:46 AM
7camaro7's Avatar
What if we just stick to street tires and no radials?
Old Aug 15, 2008 | 10:16 AM
kinglt-1's Avatar
Just make sure you don't wheel hop, that is usually what takes the 10bolt out!
Old Aug 15, 2008 | 10:18 AM
tbird31's Avatar
this isn't necessarily true. a well setup rear end should be just as strong as a 3.42 rearend. you just have to have someone do it who knows what they're doing.
yea 4.10s are a little more prone to break, but unless you're going to the track weekly or doing hard launches all the time, i wouldn't worry about it. even running radials.
Old Aug 15, 2008 | 10:22 AM
kinglt-1's Avatar
I wonder why most shops around my area won't install 4.10's in a 10 bolt anymore, hmmm...
Old Aug 15, 2008 | 10:41 AM
slick1851's Avatar
My 4.10 gears in my LS1 were great daily driving, didnt even need to give it gas at a stop to get going.
FYI street tires dont like them lol!
Old Aug 15, 2008 | 10:42 AM
slick1851's Avatar
If your DD id go with 3.73s
