aluminum driveshaft?
Old Nov 24, 2008 | 10:19 PM
  #61
CamaroRacing12's Avatar
Originally Posted by AChotrod
It does look shorter doesnt it??LOL!
hahaha OMFG i thought i was the only person who thought that... i was a bit worried but one 3/4 throttle up the street with open headers cooled my senses ... i have had 0 issues with the driveshaft... good easy cheap mod IMO, great one for Newbs like myself to do on their own and feel satisfied about ...
Originally Posted by James Montigny
Raise car on jackstands.
Unbolt Ujoint retainers (4 bolts)
Push driveshaft into tranny about 1/2 to get it free from rear end
Pull out of tranny, watch for trans fluid drip
Install new shaft
It's literally a 20 min job ... and only if you drop the shaft on your forhead head and cuss for 5 min of that LOL
haha yep it def is! i did the ls1 aluminum driveshaft, SS3600, CPT Pro Race rebuilt 4l60e, and madz28 tuned pcm, all at the same time.... went from a 13.3 to a 12.49.... i loved it... and doing it on my own (with a more expirenced buddy) made it all that much better.....
Old Nov 24, 2008 | 10:24 PM
  #62
the_merv's Avatar
Veteran: Air Force
The U-Joint Strap Bolts are 11mm..
Old Nov 24, 2008 | 10:48 PM
  #63
i knew they were small and some odd size... i was about to type 10mm but i figured that was too small.... damn u merv and ur expirence lol
Old Nov 24, 2008 | 11:00 PM
  #64
the_merv's Avatar
Veteran: Air Force
Lol..
The ones on my Moser are 1/2 Inch..and they are U-Bolts.
Not my fault I know just about every Bolt on my Car..
Old Nov 24, 2008 | 11:24 PM
  #65
gold98Z28's Avatar
Aluminum shaft swaps are quick and easy.
It will reduce parasitic hp loss in the drive train and reduce vibrations at higher RPM.
I've done these on dozens of cars for people over the years.
It's a bigger deal for the 3.4 crowd because they had a big heavy 2-pc steel shaft.
Guys running 11sec or better tend to trade those in on chromeoly or beefier aftermarket aluminum shafts.
Even the 3" LS1 shafts tend to shred under 1.5 launches LOL
Expect to pay $75-125 for one (used)
They pop up on ebay and in the classifieds a lot.
All 82-02 shafts (auto or manual, v6 or v8) are interchangeable.
And remember to install a new Ujoint as part of the project, it's cheap insurance.
almost correct, the third gen manual cars where longer, all others the same... maybe it was just the four speeds? i know there was a few 82-83 cars that had a longer one. i pulled one to use it one time and was like, WTF this is too long. haha
Old Nov 25, 2008 | 12:48 AM
  #66
Lol..
i hope to get to that point one day, im only 19 tho a hungin...
Old Dec 6, 2008 | 04:26 PM
  #67
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Is the Lingenfelter a stronger shaft than the LS1 shaft. It's 3.5" shaft, but isn't cheap.
Old Dec 6, 2008 | 08:13 PM
  #68
im sure it is.... but im sure u wouldnt break a in shape ls1 shaft with ur mods in sig unless u launch dumping the clutch at 5500 pass after pass
Old Dec 7, 2008 | 01:42 AM
  #69
the_merv's Avatar
Veteran: Air Force
I just bought a LT1 1LE DS for a backup DS for my Car, some have said that it's a little stronger than the LS1 DS.
Old Dec 7, 2008 | 07:57 AM
  #70
BTC's Avatar
BTC
My car will probably never see the track. I'm just gathering info because I definitely want to get a new driveshaft. My car used to vibrate pretty bad starting around 70mph. I'll probably get something new, as opposed to used. From what I've been able to determine, a new LS1 shaft is well over 300. I was just curious if the Lingenfelter shaft was superior in comparison. I've heard some people have had issues with 3.5" shafts coupled with 3" catbacks, so that's something else I have to consider. I guess Denny's, or another company, could make a 3" aluminum shaft.
Old Dec 7, 2008 | 11:56 AM
  #71
AChotrod's Avatar
Dude just buy a used LS1 shaft. Dont waste money on a new one. Mine was a night and Day difference over the stocker.
BTW I weighed my ls1 shaft with u-joints and yoke it was 13.22LBs on a digital scale at UPS b4 boxing and shipping it out.
Old Dec 7, 2008 | 02:42 PM
  #72
Teal94Z's Avatar
is it a noticeable gain in hp gain from using an aluminum ds vs the stock steel?
Old Dec 7, 2008 | 02:45 PM
  #73
AChotrod's Avatar
No not really I didnt notice anything on the track or street! 100000X smoother though
Old Dec 7, 2008 | 04:38 PM
  #74
yea x222 on not wasting ur money dude.... get a used ls1 shaft off a 65k mile ls1 or something... night and day difference with vibration... and im sure it cant hurt performance wise....
Old Dec 7, 2008 | 10:40 PM
  #75
-DIABLO-'s Avatar
i have 4 ls1 drive shaft for sale 100 + shipping
Old Dec 7, 2008 | 11:39 PM
  #76
the_merv's Avatar
Veteran: Air Force
^^That's pretty much the going rate..
Old Dec 8, 2008 | 04:19 PM
  #77
yep
Old Dec 8, 2008 | 11:41 PM
  #78
the_merv's Avatar
Veteran: Air Force
I just snagged a 1LE LT1 Aluminum DS out of the Classifieds section for $110 shipped. I got it for my Car as a backup, it has a 1350 U-Joint on it already too, so it's a direct bolt-in to my 9".
Old Dec 8, 2008 | 11:44 PM
  #79
Elliott's94Z's Avatar
Bought mine used with maybe 500 miles on it for dirt nothing
Old Jan 7, 2009 | 08:18 AM
  #80
BlackTA96's Avatar
When switch to an aluminium drive shaft, do you need to change out the yokes?
(put the yoke from your lt1 driveshaft on to the ls1 drive shaft)
