What the heck was this?
Second try,same thing except I held in the start position for a few seconds,it spontaneously came to life while holding it there and started to turn over,but I let off before it would start.Third try,it started normally,but was barely holding idle at 400-500rpm,sounded like the dang thing was cammed,which was cool,but obviously this wasn't normal.Gave it a little gas,but the idle would come back down to 500ish.
Fourth try, took the key out completely,put it back and turned onto the ON position, had gauge lights and the fuel pump primed as normal,car started flawlessly and held a normal cold idle at 1,000ish rpm.Took it for a short drive,reached closed loop,came back home,turned it off,tried cranking again and it started good again and held a good warm idle.A couple hours later I went out again and the car started and idled as it normally should.
What happened? My first thought was that the resistor on my key might be wearing out,but I wouldn't think that would cause such an abnormal cold idle,so I have no clue.No SES or security lights.The positive battery cable was a little corroded when I was replaced the battery about 2 weeks ago,but I cleaned it off and put some anti corrosion stuff on it.Any ideas?
Thanks.
Mine did that and eventually it got bad to where it heated up melting the main power-in wire off of the Battery, and then it finially gave out, grounded out on the Steering Column, popped the Fusible Link under the Hood and left me motionless on the side of the Highway.
Thanks
Sometimes on/off.....on/off......on/off....
new opti, ignition module (maybe try this too), water pump-bearings shot, plug & wires-always a good idea, coil = $$$$$
