Summit vs. BBK TB, whats the difference?
cause your sig says your all stock, there are much better more efficient ways of making power as im sure tons of people will be in here in a minute saying a 58mm TB is not needed until you get a large cam or heads and cam package.
so if youre thinking it would be a cheap peformance mod, it honestly wouldnt and you might even lose a little hp going to a bigger TB if you have a completely stock car.
you need to first concentrate on getting the spent gases out of your car before you try to add more fuel and air to make power.
just my .02 cents
Some of the TBs are crappy. Im not sure but I think the brothers or something makes it for summit and those are crappy. Maybe its Jegs but anyway all TBs are NOT created equally. Some come with TPSs others dont, some dont idle well either and need the drill mod. Stay with a name brand designed for an LT1 Not a universal one.
Im in the market too so lookig forward to seeing what the boys have to say.
1) None of the custom plates fit the top.
2) They can open beyond Full Throttle and cause a problem (I did not have an issue but another member whom I trust told me about it when we traded his BBK for my Holley) however some have a plate to stop it and have a write up on how to do it. It can cause a CEL if the problem exists.
3) If you even just have small supporting mods you will lose power. I had a full LT4 build, Heads, IM, Cam with porting and I lost power as well as got some fun throttle delays (Hit the gas and it did not move then suddenly did... TPS needed to be set for the Holley to fix it).
I really did like it, everything needs minor work but there's some info.
The BBK I have required a mod to idle correctly which it already had thankfully.
damn it, I forgot what it was. Maybe adjust the tps???.
ASM also looks nice. Any problems with that one?
Mec
