wtf ?????HELP ASAP
Old Sep 15, 2008 | 09:21 PM
baylove's Avatar
Default wtf ?????HELP ASAP
after installing my pacesetter long tubes my steering linkage is hitting my headers why is that ?? the last long tubes i had on my car i didnt have this problem ANY IDEAS ???
Old Sep 15, 2008 | 09:28 PM
baylove's Avatar
Old Sep 15, 2008 | 09:32 PM
glenb1991's Avatar
no idea... i have pacesetters on mine and never had this issue... i say just check the way everythings welded together.... maybe your exhaust is offest to that side so much when it got welded together the header got pulled that way a lil bit... just an idea.
Old Sep 15, 2008 | 10:05 PM
baylove's Avatar
I guess i need to shave down my steering linkage or something
Old Sep 15, 2008 | 10:42 PM
jarretthise's Avatar
you really dont want to make your steering linkage any thinner tahn what it is..its thin enough...just send them back and tell them what the deal is...
Old Sep 15, 2008 | 11:26 PM
Kolt@FuzionAuto's Avatar
Yeah call up pacesetter for sure!
Old Sep 15, 2008 | 11:28 PM
94CamaroZ28SS's Avatar
i second that the last thing you want to do is screw the sterring linkage up just to install headers. return them and tell them they dont fit maybe you got a bad set or the wrong year?
Old Sep 16, 2008 | 12:07 AM
baylove's Avatar
damn i dont want to take them headers off again its too hot in arizona but i guess you guys are right i will give them all call tomorrow thanks
Old Sep 16, 2008 | 12:08 AM
texas94z's Avatar
Pics man. That could help us. Part number???
Old Sep 16, 2008 | 12:16 AM
AChotrod's Avatar
Did you loosen the steering colum bolts and slide it over yet? You can also just slot the bolt holes a bit to get just a bit more room.
Old Sep 16, 2008 | 12:32 AM
baylove's Avatar
i havent taken any pictures yet but i will tomorrow when i get home from work my car is a 95 z28 camaro the headers i ordered were pacesetter lt ceramic coated
part number 72c2239
http://www.byunspeed.com/product_inf...40de17b8fd4c46
before i installed these i had pacesetter lt painted headers with emissions and i had absolutely no problems with those
Old Sep 16, 2008 | 02:20 AM
Formula350's Avatar
So you bought ceramic coated ones even when you had the same ones, but painted? Could've just had the ones you already had, ceramic coated...
Old Sep 16, 2008 | 08:03 AM
baylove's Avatar
no i went with race style long tubes NON EMISSIONS
Old Sep 16, 2008 | 09:46 AM
AChotrod's Avatar
Did You See My Post???
Old Sep 16, 2008 | 10:03 AM
robsquikz28's Avatar
either way those headers should have never hit ur linkage there is something wrong with the header design or maybe bent linkage if its not the linkage then u need to call pace and get new header
Old Sep 16, 2008 | 10:17 AM
baylove's Avatar
ok will call them now because the linkage is just fine never been in a wreck i didnt bend it the other long tubes fit just fine thanks for all your help everyone
Old Sep 16, 2008 | 10:31 AM
grn95t/a's Avatar
mine hit the plastic heat shield and melted it. is that what yours are hitting?
Old Sep 16, 2008 | 10:38 AM
baylove's Avatar
the painted long tubes did before but it melted off and fit fine its actually hitting the linkage itself rotating bar that connects to the rack and pinion and steering column
Old Sep 16, 2008 | 10:53 AM
baylove's Avatar
heres a picture (7) shaft assembly steering gear coupling
Old Sep 16, 2008 | 10:58 AM
Formula350's Avatar
Yea, so basically the same headers. You could've just cut off the emissions provisions or welded a plate on it.
Example for 97-01 Vettes, other than the angle of them for picture, look at the difference.
"Race"
Emissions
Conlusion: There is no reason they should hit and you wasted some money
