How Aggressive is your build
...Well until I start it and all hell breaks loose.
I have religated it to a Street legal Race car of late. The car is fully street legal and NHRA legal to 8.50. Damn thing only runs high tens N/A though
mods deem it hardcore, but it is built for the street.
Then I slowly drift off to comfortable sleep knowing that I have a ways to go before I split my block in half...
Taner other than the clutch explosion have you ever had a REALLY nasty internal mechanical failure with the nitrous motors that you have run in the past few years? I don't know if you keep it under wraps but I don't think I've ever heard of you really hurting something.... Jesus himself either tunes your kit, or builds your motors...
as well, tuneups kill motors not hp, things don't move around unless the motor isn't happy. bad tuneups splits blocks. detonation is not your friend, lmmfao!!! just ask Dr. Detonator (inside joke)
i have not had any sort of catastrophic failures with my stuff. other than tweaking a ringland (and i do mean tweaking by a couple of thou.) keep in mind you can be rich many times but lean only once.
as far as tuneups on the bottle, it has been a learning curve from day one, i first trusted the folks at Agostino racing engines to guide me, after seeing a friend grenade his **** 2 times, and then me lifting a ringland after following THEIR tuneup to the flippin' letter, i decided that i needed to start asking the right people on basics to running a pro shot fogger. since then it has been a positive learning curve!
i went 9.3 a few weeks ago, on a very softly progressed tuneup at 149 mph. needless to say i was stoked! the track prep was f'n garbage out past 100'. so i had to ease in the nitrous every gear for 0.6 seconds, and i progressed it all the way thru 1st gear to 80%. as well my plugs looked the best i think they ever have after that pass(on the bottle)! as well with help from my engine builder on properly reading plugs, i have learned a ton over the past few years!
my transmission woes and as of late clutch issues have been my most recent nagging problems. the mcleod in the car is working great! trans is great! motor is great, and come sunday we'll see if the driver is just so so
So are you shutting the car down as soon as you cross the finish line and towing it back to the pits???? I assume since you are pulling all your plugs and reading them.....
takes about 20 minutes with the motor hot to yank all 8 and pop in a different set of plugs.overkill is good if you can bite the bullet and spend the money the first time! it saves you in the end i am sure of it.
