destroyed rear dif
Old 09-26-2008, 08:39 AM
stevens's Avatar
Default destroyed rear dif
so i blew up the "stock" rear end in my 97 ss 6 spd yesterday, im wondering if anyone else has gone through this and what they did to make it stronger/faster?
thanks
Ryan
Old 09-26-2008, 08:44 AM
hawk584's Avatar
mine blew up as well 2years ago. i ended up getting a new one from the junk yard for 300$. if i had more $$ i would have gotten a 9'' or an S60... when ever it is i do get the green i'm going to spring for the S60 though
Old 09-26-2008, 09:41 AM
tbird31's Avatar
been through a 4.10 already. put the stock rear back in. welded tubes and cover on both rearends.
only way to make a stock rear "stronger" is to weld the axle tubes and put a cover on it. if you decide to weld the axle tubes be careful and go slow, you don't want to have any deflection or turn the tubes while welding.
Old 09-26-2008, 10:12 AM
connexion2005's Avatar
Aren't the tubes already welded to the pumpkin?
Old 09-26-2008, 11:07 AM
Stroked96Bowtie's Avatar
thanks
Ryan
Congrats ryan! The old 10-bolt just put another hashmark on the sides of camaros everywhere!! Another one bites the dust. Get another stock one...be easy on it until you can get a heavier duty rearend. Any money spent on a 10bolt is just a bandaid to the real problem...keep the gear ratio low also...it'll help.
Old 09-26-2008, 11:09 AM
fergymoto's Avatar
^You mean keep the gear ratio high
Old 09-26-2008, 11:15 AM
Yep was thinking in terms of ratio numbers I guess...you know what I mean.
Dont go off and put 4.10s in it!! Mid to low 3.xx ratio is what I was thinking.
Old 09-26-2008, 11:33 AM
4.10 is a lower gear than a 3.23 would be...I understood what you were saying.
Old 09-26-2008, 01:25 PM
k0261886's Avatar
Actually 4.11 and 3.90 gears are some of the strongest gears.
Old 09-26-2008, 01:34 PM
the_merv's Avatar
The Gears are strong, but they do very well in applying the Torque to the ground, and that is what blows up the 10 Bolt.
I killed an aftermarket one that I put in after I killed the stock one. It went out in a glory of a 8" wheelie and shattered all the teeth off of the 2 center Spider Gears.
To solve that I invested into a Moser 9". I would suggest that if you intend to build up that M6 Car.
Old 09-26-2008, 02:37 PM
k0261886's Avatar
^ Ah I see. My bad
Old 09-26-2008, 03:02 PM
1994Z28Lt1's Avatar
i broke one full tooth off the pinion gear and the next 3 in a row were cracked and on their way to break
this was with the stock 3.42's M6 and probably about 300 rwhp (haven't dynoed since it put down 271 dead stock)
i wish i wasn't in school and could drop 2500 on a 9inch
Old 09-28-2008, 07:37 PM
stevens's Avatar
ya im trying to decide what to do. i rebuilt the motor last year n stroked it to a 383, i figured it was just a ticking timebomb, i havent got the cover off yet im not sure how bad it is in there. sounds pretty bad though.
Are the moser products any good? an does anyone know how they compare to stock?
Old 09-29-2008, 08:16 AM
the_merv's Avatar
^^You're not going to break a Moser 9" with that 383..the basic setup I got will out-last my 402 and T56 easily..
