Shifting problem persists; unable to shift quickly.. HELP!!
Old Nov 25, 2008 | 10:58 AM
  #81
Aetos's Avatar
After talking to Joey I'm gonna take the following steps
1) Redo clutch disengagement test.
2) Bleed my hydraulics until hell freezes over.
3) Get a Tick master.
4) Transmission rebuild.
Old Nov 25, 2008 | 08:50 PM
  #82
BlkZ28559's Avatar
We feel your pain. My 98 z28 has 81k miles still on the stocker I can't down shift from 6-5 I have to go down to 4th and upshift.
Old Nov 25, 2008 | 09:27 PM
  #83
Aetos's Avatar
Atleast your "fun" gears still work
Screw bleeding this stock POS. I'm ordering a tick master tomorrow,lol.
Old Nov 26, 2008 | 04:36 PM
  #84
Aetos's Avatar
update:
MY CLUTCH DISENGAGEMENT TEST FAILED!!
Right after I parked today, I stuck it in first, clutch down, reved to like 5-5.5k and was like screw it, nothings happening so I let go of the throttle, by right before I did I felt it move. So I tried it again to like 5.5k-6k AND THE CAR CREEPS!
YES!!
Old Nov 27, 2008 | 01:09 AM
  #85
CW00BlackTA's Avatar
Cool! Progress is being made. Beats having to yank the transmission too.
Old Nov 28, 2008 | 05:38 PM
  #86
nasty96's Avatar
yea i have had the same problem with a ls1 you should have left the mighty vac on over night at least there's a lot of air in the bottom ... does it go into 1st and reverse ok from idle.. cause it sounds like the clutch is not fully disengauging....but it really sounds like hydralics weather its air or just faulty parts and i've seen new GM. master and slave units not work from new....
Old Nov 28, 2008 | 05:54 PM
  #87
LivingCanvas's Avatar
Ill put money on the Tick master fixing it. Like has been stated a hundred times in this thread, the stock hydraulics, no matter how new, are not up to the task of powershifting. They simply do not move enough fluid fast enough. Every once in awhile you see some ones stock stuff wroking good, but those are factory freaks
You could have bought several tick masters for the money you have put out chasing this problem.
Believe me, I have tons of experience with these trans/hydro systems.
Old Nov 28, 2008 | 07:34 PM
  #88
BlkZ28559's Avatar
Tick master but what slave should go with the tick master???
Old Nov 28, 2008 | 07:42 PM
  #89
Aetos's Avatar
Not really. My pressure plate was still pretty bad according to the mechanic so that needed a switching.
Old Nov 29, 2008 | 08:24 PM
  #90
SuperSport4life's Avatar
01-02 GM Slave works good for me!
Old Nov 30, 2008 | 11:21 AM
  #91
MrElectric03's Avatar
Cant believe it hasnt been said yet but a shim behind the slave will help for sure. I did it when I had the problem on my car and it worked. It can also be fixed with an adjustable master.Speed Inc sells the shim for about $15, then you need to pull the trans, unbolt the slave,put the shim in and bolt it all back up.
Old Dec 1, 2008 | 10:39 AM
  #92
8th sin's Avatar
when are you planning your install. I will be ordering a Tick MC on Thur as long as everthing goes well. I hope this fixes your problem.
Waiting on updates
Old Dec 1, 2008 | 11:36 AM
  #93
BlkZ28559's Avatar
Thnx bro
Old Dec 1, 2008 | 12:18 PM
  #94
Aetos's Avatar
Just got off the phone with Joey from Tick Performance, cool guy. Just placed my order for a master cylinder.
Hopefully this solves all my problems.
Old Dec 1, 2008 | 03:11 PM
  #95
airforcemanss's Avatar
update:
YES!!
what does this mean;failed clutch test?
im still waiting on my adj master...i did get a free upgrade though because of the extended wait...so how much longer joey?
once i get this installed ill let yall know how i turned out;hopefully another tick master sucess story.btw should i get the master installed first then try it out with stock shift opponents before i throw the pro 5.0 w/ short stick? i think i wanna see the difference, whadda yall think?
Old Dec 1, 2008 | 03:43 PM
  #96
Sharpe's Avatar
Same problems. Going hard, get "locked out" of third. Was told it was my blockers.
Old Dec 1, 2008 | 04:18 PM
  #97
Aetos's Avatar
Its not really the same problem as me. One gear usually means internal problems. All gears usually means hydraulic problems, unless you're extremely unlucky and had all your syncros/forks go bad.
The clutch test is the following:
1) Go to a FLAT street(this is vital)
2) throw your car into first and hold your clutch pedal all the way down
3) Rev your car to about 5.5-6k while still holding your clutch pedal down and emergency brake off
4) If your car moves it means your clutch is not fully disengaging which usually indicates hydraulic issues.
Old Dec 6, 2008 | 10:16 AM
  #98
It probably seems like you are locked out of third but its really just the angle of the shift. Either a shim behind the slave or adjustable master would fix your problem, there is the cheap way and the right way.
Old Dec 15, 2008 | 10:38 PM
  #99
Joey@Tick's Avatar
LS1TECH Sponsor
Somebody should be getting a surprise in the mail very soon...
Old Dec 16, 2008 | 06:17 AM
  #100
hymey's Avatar
keen to see results of this.!
