Old thread but I donīt want to open another one on exact the same topic. Does anyone have part numbers for his T56 that fit?
Seems that I have an older T56 (GM part 12550647, Borg Warner 1386-009) from 1994 - 1995 with following bellhounsing no: Borg Warner 13-86-212-901-H and it does not fit to my LQ4, just a little bit too small. Drive-end view engine bellhousing T56
If that T56 was originally bolted to an LT in a Camaro or Trans Am, you have to change the input shaft and the front plate on the transmission. Same thing I had to do. The reason I say this is you say it is a 94/95 model, which would be the LT engines...not an LS...yet. You'll also need the bellhousing. I bought everything (bell, flywheel, clutch, etc) for a 2002 Camaro after I got the plate and shaft swapped.
Reason: forgot to add...
