compare between two GM and RAM
Old Dec 27, 2008 | 08:09 PM
PONTIAC SLP's Avatar
Default compare between two GM and RAM
hi , what is the best guys and why please explane
- GM Clutch Master Cylinder
- RAM Adjustable Clutch Master Cylinder
Old Dec 27, 2008 | 08:33 PM
DONAIMIAN's Avatar
Same thing except the ram is adjustable.
Old Dec 27, 2008 | 08:37 PM
hmm , what do you recommend me to run with ?
Old Dec 27, 2008 | 08:55 PM
HavATampa's Avatar
Tick Master Cylinder.
https://ls1tech.com/forums/showthrea...ferrerid=13535
http://www.tick-performance.com/cata...ody/driveline/
Old Dec 27, 2008 | 08:58 PM
lool i said between RAM and GM that thing is expensive like mecloud
Old Dec 27, 2008 | 09:09 PM
HavATampa's Avatar
There is a writeup in the stickies to make your stock one adjustable like the Ram for a few dollars, so I wouldn't buy the Ram. The problem with the stock MC is it's small bore diameter and is cheaply made. I don't like spending $300+ on the Tick either, but after reading all the posts about the problems it's fixed and after all the money I've wasted on stock parts that never resolve the shifting problems, it's a no brainer. If you still want a stock GM unit, wait a few weeks, there will be a flood of used ones for sell including mine as soon as I install the Tick.
Old Dec 27, 2008 | 10:29 PM
03 BUSA's Avatar
Tick here as well. The Ram is just a factory unit that they made adjustable.
Old Dec 27, 2008 | 11:48 PM
ae13291's Avatar
go factory
Old Dec 28, 2008 | 04:09 AM
DONAIMIAN's Avatar
I personally run the ram, not saying that the Tic product isn't good or anything. Ive just had success with the ram unit so there was no need for me to upgrade.
