T56 gear grind when cold. Normal?
Right after starting the car and pulling out of the driveway, if I shift just a tad to quick when its cold out, I occasionaly get a small gear grind.
This can happen for maybe a mile and then it never happens again till the next morning. I assume the tranny needs to warm up a bit.
Never happens after the first mile or so.
Normal?
Normal?
Mines does the same thing, usually it only does it the first time I shift and thats it. But if it sits for over a week and its cold out, usually takes several miles till it stops, its just cause its cold.
I have the same issue as well. A small amount of grinding when the trans is very cold first thing in the morning. Always goes away when hot. I'm glad to see this thread and find out I'm not the only one. Sounds like I may have a fluid change in my future maintenance plans. We'll see how it goes from there. Until then I shift very carefully until the car has warmed up.
