Clutch Pedal Return Spring?
Old Jan 13, 2009 | 01:51 AM
Jerrod4567's Avatar
Default Clutch Pedal Return Spring?
When I was changing my clutch master cylinder today, I took off the body panel under the steering column and a spring fell out broke in 3 pieces. Seems that it was a return spring of sorts for the clutch? Whats funny is that even with that gone, the clutch pedal feels the same... works fine, returns to position etc... Is this something I need to worry about replacing? Strange...
Old Jan 13, 2009 | 01:55 AM
dragon93308's Avatar
ive had that fall of a few cars in the past.. nothing ever changed. youl be fine
Old Jan 13, 2009 | 01:58 AM
the_merv's Avatar
Veteran: Air Force
I'm trying to figure out what that spring is used for, the LT1 Cars don't have it.
Old Jan 13, 2009 | 02:34 AM
Halloran's Avatar
Spring isn't needed an it's like a $25 part from GM. Yeah a $25 spring...go figure. And it's even more of a pain in the *** getting it back into place. Dump the spring, and you'll be fine.
Old Jan 13, 2009 | 08:43 AM
drews94z-28's Avatar
lol my friends did the exact same thing on his 01, yeah luckily its not needed
Old Jan 14, 2009 | 10:37 PM
jattgunman's Avatar
Yes the searched gods worked!!!I tried the drill mod and I broke the stupid spring and got hella worried but guess its not to important my dad said that it probally doesnt do anything the way it was in there anyways..
Old Jan 17, 2009 | 09:31 PM
HavATampa's Avatar
Tick recommends to take the spring off when installing their master cylinder. Screw that spring.
Old Jan 18, 2009 | 12:22 AM
_JB_'s Avatar
lol yeah mine has been MIA for over a year now. Never had a problem with the pedal coming back up.
Old Jan 18, 2009 | 12:09 PM
SladeX's Avatar
I found I had to adjust my clutch safety switch a bit with the spring gone else I couldn't get my cruise control to work (but at the same time I still couldn't get it started unless it was fully released). Seems as though the clutch safety switch is pressure or position sensitive.
Another note is that IF you don't run the spring, the switch can actually take a beating from the quick release of the clutch. The spring worked in a sense that it put a directional force opposite the pedal at a certain point to prevent the switch from taking a bad impact. That said, I'm not buying another spring. Waste of cash. The replacements are just of poor quality if not worse now.
Old Jan 21, 2009 | 09:53 PM
jattgunman's Avatar
Im going to purchase a replacement spring afterall because right now I am unable to rest my foot on the clutch pedal while driving because thiers to much play on the top of the pedal which is causing eradic disengaging..Does anyone know a cheap source for the spring?I called a dealership and they said its 40 DOLLARS!!!!
Old Jan 22, 2009 | 08:25 PM
HavATampa's Avatar
$40!!! Geez! Riding your foot on the clutch is a bad thing anyway, you'll wear out the throwout bearing at the least. Forget about the spring.
