centerforce clutches?
I put the 12" DF in my Z06, but sold it during the break-in miles, so I never got to beat on it. It had awesome street manners, and pedal/release was like stock LS6 w/stock hydraulics. Was behind a built LS6 with 233/239 TSP cam (kinda lumpy, needs approx 900 RPM idle). I could lug the thing from a stop, letting the pedal out gradually, almost killing the engine, and there was no shudder, shaking, jerking, or grabbing.
I will probably get this same Centerforce 12" DF to replace the SPEC II in my Formula (in anticipation for 450-470 RWHP LS1/LS2).
I would not waste my money on any GM clutch. I don't think their pressure plates are any good for serious street use or occassional race use.
the cfdf12" is a good clutch from what I here, two of my freinds have the 11" and it holds 525hp on slicks.the 12" is bigger more clamping surface and supposed too hold up to nitrous use . THE DFX i have heard little about so far but its supposed to grab like a **** and hold big hp. but will from cf says that the df 12" is better for dd. I had a spec stage 2 it was junk only held up to 5k miles.
I had heard some good things about the 11" DF, but then a few others looking into Centerforce clutches said they had heard of a few issues with the 11". However, the 12" DF came highly recommended, with a handful of 500-525 RWHP guys giving good reviews. Really didn't find anything negative against the 12", compared to the Texs, SPECs, LS7s, and a few other singles. Still, much of this is '3rd person' accounts, and my research ended about 3 months ago.
The DFX is their new 'thing', but I have seen the Centerforce rep (active on these forums) recommending the 12" DF for many LS1s, from bolt-on cars to nitrous/DR users. They are very insistent about proper break-in and a fresh/new flywheel surface.
I just put a new one on and it holds like a sonufabitch. I tore the rear bearings a little and stripped teeth on the axle stub. Car put down 350/350.
I am more than satisfied. I was going to get a Monster, but I decided that paying 351$ was better than 700$+
The DF is a 12" disc, the DFX is an 11" Disc.
The shifting problems you heard about were on the old design, the 12" does not have this problem.
It is rated at 650 RWTQ although I do not personally believe this
You can use your stock flywheel if it is resurfaced AND BALANCED, balancing is a must.
Street manners were great on mine, customer service has been meh since it took a dump with under 1,000 miles on it. Its on its way to them for inspection and I have to wait to see what they say.
i do read. in fact i have been through pages and pages of rambling posts that do not answer my question. i just want a straight answer that gets directly to the point.
