Drill Mod = Failure Need Help
I decided to do the drill mod to my 2001 camaro ss and within 15 minutes of starting I broke the clutch pedal spring!!! So I put everything back together and gave up only to start doing it again 5 minutes later. The master cylinder took almost a hour to get out and even longer to get in and this was with two people working on the thing. So we finished up almost 6 hours later and the clutch pedal has no pressure,We bled the the system through the quickconnect but not through the bleeder valve.Would renting a mighty vac work?or should I just get back in there in the morning and use the bleeder valve?
I'm probably not much help for ya but I would recommend Ticks upgrade. Pretty cheap for the performance and Life of your tranny, trust me I wish I would have done it earlier.
http://www.tick-performance.com/tick...dy/hydraulics/
when I did the drill mod I didnt have pressure right away. It took about 30 times of opening and closing the bleeder valve to get it just right. I would try the bleeder valve before the vacuum
How exactly did you bleed the system "through the quickconnect"? The proper method to bench bleed it is to open the quick connect fitting with something small (5.5mm socket works perfectly), stroke the master pushrod all the way inward, and then close the quickconnect and release the pushrod. Do that until there is no more air coming out.
Then you need to attach the system back on the car and bleed it through the bleeder screw so that the slave can be purged of any trapped air. The proper method for that is to push the clutch pedal to the floor, open the bleeder, let the fluid/air out, close the bleeder, and then pull the pedal back to the top of its travel and repeat. Do that until only fluid flows out of the bleeder, with no air at all. Also make sure to keep the master topped off, if you let it go dry you will need to start all over, from square one.
And for some reason my master cylinder wouldnt budge no matter what we tried, we tried prying from the engine bay to tapping from the inside. Then we knew something was up and decided that maybe we should give up 'cus it would be helllll to get her in if getting her out was being sucha pain.and we were right
the hardest jobs are the ones where the instructions state "use your fingers as your eyes"
Ok so ill bleed the clutch the traditional way and ill also mighty vac just as back up...is that cup thing on a mighty vac supposed to be full?or empty
Ive been trying to get pressure back into the clutch but it doesnt seem to be working!Im having someone press and hold the clutch while I open the valve and then I close it and he brings the pedal back up..weve done this a ton of times and nothings working
