View Poll Results: Mcleod or Quick Time Bell Housing
Mcleod
15
38.46%
Quick Time
24
61.54%
Voters: 39. You may not vote on this poll
POLL:Mcleod or Quick Time Bell Housing
Old Feb 24, 2009 | 06:53 AM
  #41
BADD SS's Avatar
Originally Posted by LSGunZ28
Well, just in case, could you give me their info?
I wanna get mine ASAP... I looked on JEGS and Summit, and didnt see any quicktime for any F bodies...
I talked to one of the people @ SNL last week, and he said he could get it for me, but I havent been able to get in contact with him..
So whoever can Chime in, please. Lemme know where you got your Quicktime bellhousing from..
Tell him Christian sent you.
https://ls1tech.com/forums/member.php?u=111709
Kaltech Tuning and Performance
http://www.kaltechtuning.com/
17 North Belle Mead Rd.
Setauket, NY 11733
V. 631 242-6444
F. 631 242-6445
Old Feb 24, 2009 | 06:26 PM
  #42
LSGunZ28's Avatar
Setauket, NY 11733
V. 631 242-6444
F. 631 242-6445
Unfortunately (or maybe fortunately) I already ordered mine today, Through SNL performance....
But thanks anyway
Old Feb 25, 2009 | 08:56 AM
  #43
Troy's Avatar
Just make sure you get the right one! They sent me the wrong one and I had to retap my engine
Old Feb 25, 2009 | 01:21 PM
  #44
LSGunZ28's Avatar
I know, I dont think they even knew I have an F body...
But how the hell did you have to re tap the engine?
Old Feb 25, 2009 | 01:49 PM
  #45
Carshopinc.com's Avatar
LS1TECH Sponsor
Hey guys...
We are a quicktime dealer... and sponsor of LS1 Tech give me call or a pm.. I have
the SFI certified units in stock... Will a offer super price..
Thanks Tim
Old Feb 26, 2009 | 03:01 PM
  #46
Troy's Avatar
I had to re tap because they sent the wrong bellhousing with the wrong bolts. The bolts/housing were a very close fit but not quite and by the time I realized something was wrong I had already done some damage. I will say that they at least were helpful in providing me with some tips to fix it and sent the correct one right away.
Old Jan 19, 2010 | 08:48 PM
  #47
bww3588's Avatar
summit sells the quick time as well.
that being said, does anything have to be done as far as shimming the slave or anything to make up for the tranny being set back further than stock?
Old Jan 20, 2010 | 12:49 PM
  #48
SantaCruz163's Avatar
I believe the Quick Time bellhousing (including the engine plate) is in spec with the OEM bellhousing dimensions. Therefore, shimming would not be necessary.
Old Jan 20, 2010 | 01:56 PM
  #49
bww3588's Avatar
can anyone else confirm this? i would like to get as close to direct bolt on as possible.
Old Jan 28, 2010 | 11:04 AM
  #50
FTSS's Avatar
I also am hoping to hear if any adjustments neccessary in the slave/t.o. bearing area. Getting close to pulling the trigger - likely on the Quicktime unit.
My setup just for whatever is important:
LS- T56 and Rhino hyd. t.o. bearing, with LS7 clutch & 168t flywheel. I'm mating to a reg. 4-bolt roller 1pc. sbc (but with 2pc. adapter).
BTW you can see I'm new to the site. Here I was hunting for some help and there's already a whole thread and stickie on it! Not too shabby.
Old Jan 28, 2010 | 12:14 PM
  #51
FTSS's Avatar
Originally Posted by Carshopinc.com
Hey guys...
Thanks Tim
I just ordered a RM6023 from Tim. I might have it tomorrow, at least by w/e. He claimed the hyd. TO bearing will be perfect for my app.
Old Jan 28, 2010 | 05:04 PM
  #52
smokeum99ta's Avatar
I'll add alittle input about the mcloed bellhousing. Well for starters the fitment isn't that good. There are three bolts on the housing that need to changed to allen head style bolts to get the proper torque on them. Which by the way really sucks cause two of them are hard as hell to get to. Thats just another overpriced product by mcloed that isn't worth a **** that some of bought cause they were the first company to offer it . So my vote go's to quicktime.
Old Jan 29, 2010 | 08:22 AM
  #53
NHRATA01's Avatar
I have a quicktime sitting in the box in the garage right now while I'm doing a clutch and header swap. Should have some feedback in another couple weeks.
Old Jan 30, 2010 | 08:17 PM
  #54
BADD SS's Avatar
The quicktime fits almost like stock, very very easy. couple bolts are a pita but its expected, no cutting/grinding...
Old May 1, 2010 | 10:28 PM
  #55
C Murda's Avatar
can someone confirm this?? i just got my QTP piece in and sold my stock bellhousing before i even knew there could be a differece in overall bellhousing height compared to stock. dont want any clutch engagement problems...
Old May 2, 2010 | 08:30 AM
  #56
cam's Avatar
cam
I have a new one sitting on my shop floor and a stock bellhousing right beside it so I can measure it for you to confirm. That said I've been assured by very reputable members and builders that the QuickTime piece is a direct bolt in replacement. I'll double check for you when I get to the shop though as I'm curious for the sake of interest to verify the dimensions myself
Old May 2, 2010 | 11:54 AM
  #57
cam's Avatar
cam
Although there is a difference of around 1mm in these pics I'd attribute that to the inner plate of the Quicktime as its just gravity holding it down and once its bolted up it would compress it that little bit where the stock bell is just once piece and has no inner. Regardless 1mm inst going to make jack squat difference in thew function of your hydraulics.
Consider this one a no brainer just bolt it in and go
Attached Thumbnails POLL:Mcleod or Quick Time Bell Housing-quicktime_t56_bell_.jpg   POLL:Mcleod or Quick Time Bell Housing-stock_t56_bell_.jpg
Old May 2, 2010 | 12:13 PM
  #58
C Murda's Avatar
thanks man those measurement are GREATLY appreciated! i guess 1mm isnt anything to worry about.
Old May 2, 2010 | 12:18 PM
  #59
C Murda's Avatar
oh one other question...whats the weight of the stock bellhousing? not too important but i did notice that my new one is MUCH heavier...
Old May 2, 2010 | 07:20 PM
  #60
cam's Avatar
cam
I dont have a scale here but the stock bell is very light. I'd guess around five pounds and the Quicktime piece is heavy i'd guess around 40lbs. Well worth hauling the extra weight for the extra safety IMO though
